Nikon Coolpix S3000 Digital Camera Logo
Posted on Jun 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon coolpix S3000 won't take a picture when the
  • sisumi Jun 14, 2011
    Many thanks for the advice. Its a relative new camera but just out o warranty. I am assuming that the battery is still fairly good. No screws are missing and the problem exists still after trying all your suggestions. Everything looks normal but still won't take a picture. A visit to the repair shop is in order I think. Thanks again.
Anonymous
Level 2:
Novelist:
  • Expert 107 Answers
  • Posted on Jun 13, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
107
Questions
Helped
19636
Points
348
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
culebreez
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 02, 2017
culebreez
Contributor
Level 1:
Answers
Questions
0
Helped
2090
Points
7
Mine stopped taking pics and the ed light would come on, but what I noticed is if I push the shutter button down hard, it took pics normally. I guess over time debris gets caught up under the shutter button.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 05, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2105
Points
I had the same issue and resolved it by deleting all of the pictures off of the existing memory card. It had pictures on the card from another camera. It worked fine, then.
Nikon coolpix s3000 incorrect parameter?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
How to turn on self-timer
Press left on the multiselector (the one-handed clock icon). Use up/down on the multiselector to select the desired delay. Press the shutter release button halfway to focus and meter. Press the shutter release button all the way to start the self-timer.
Full details are in the "Taking Pictures with the Self-timer" section of the manual (page 32 in this copy).
Nikon Coolpix S3000 download from machine to pc
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
How do you use the timer?
Press cursor-left (marked with a one-handed clock) to bring up the self-timer menu. Use cursor-up/down to select the desired mode and press the OK button. Start the self-timer by pressing the shutter release button.
Full details are in the "Taking Pictures with the Self-timer" section of the manual (page 32 in my copy).
When I connect the Coolpix S3000 to the computer to transfer pictures, it turns off and won't turn on
I've had some S3000's become gimmicy when connecting to a computer. The easiest way I've found to get photos off of the camera is to use a card reader connected to your computers USB.
I tried to install software which came along with my digital camera nikon coolpix s3000. After installation I opened the icon but it showed some error. I need to transfer pictures from camera's internal...
If you need it, you can download the current versions of all (free) Nikon software from
To copy pictures from internal memory to the memory card, press the Playback button, select MENU, then select Copy.
Have a nikon coolpix s3000. lost the box with the directions. how do i download pictures to a computer?
You can download all (free) Nikon software from
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
