HP LaserJet 4300 Printer Logo
Posted on Jun 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help. Thanks
gggg
Level 3:
  • Master 904 Answers
  • Posted on Jun 16, 2011
gggg
Master
Level 3:
Answers
904
Questions
Helped
520483
Points
1791
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Set up wirelessprinter hp
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
2answers
I can't print from my network printer E260
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP addressrange that the router issues to the computers on your network and configure thestatic IP address in the printer's network configuration accordingly.
2answers
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
2answers
Hp laserjet 3055 offline when print out via networking when direct to the laptop, its working fine.......
Go to reports print configuration page it will give to netwrok configuration page check if the printer IP Address is in the same range of the IP Address of the laptopn.
If yes than check if you are able to open web browser of the printer on lkaptop using IP address of the printer if yes in laptop go to printer driver properties there go in Ports Tab and check if the Standard TCP/IP Port has IP Address of the printer of some other IP Addressif it is different IP Address than change it to the IP Addess of the printer.
Thanks and Regards.
How do I set the IP address on my HP 8150
1. Launch your web browser.
2. In the Address: or Go to: field, type the IP address assigned to the
printer (for example: http://192.168.1.1) or the host name (for example:
http://myprinter).
If you do not know the IP address for the printer, it is listed on the
printer configuration page under Protocol Information in the TCP/IP
section.
To print a configuration page:
a. On the printer control panel, press Menu until INFORMATION
MENU displays.
b. Press Item until PRINT CONFIGURATION displays.
c. Press Select to print the configuration page. After the process is
completed, the printer will return to the READY state.
From there, you can configure the printer using the web GUI. Consult the manual if you need at:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl10150/bpl10150.pdf
Hope this helps, and have a good weeked.
2answers
Printing only test page
when you click on the print in Microsoft Word is the printer there, is it set as the default printer?
Try this:
 click on File
Print
right click on the printer
go to Properties
Set as default printer
1helpful
4answers
Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
k24674
Grand Canyon Tech
Grand Canyon Tech
