This means that there is a problem with your power supply. Follow these steps to get your Xbox 360 up and running again.
The first thing you will need to is check the color of the power supply light, located on the rectangular box that your power cord is connected to.
If green
If problems persist then there is a malfunction with your hardware and your Xbox 360 will need to be sent in to get repaired.
If red/orange/not lit
If problems persist try
It means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
SOURCE: Xbox 360 3 red bars
THINGS TO TRY
SOURCE: my xbox 360 get 3
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new. It is a heat sync problem that has to be repaired by someone with indepth electronics knowledge. THERE ARE OTHER EASIER ISSUE TO REPAIR I JUST NEED MORE SPECIFICS AS TO PROBLEMS EXPERIENCED. try this link as well http://www.zimbio.com/Xbox+360/articles/332/One+Light+Two+Lights+Three+Lights+More
