Question about Powr Flite PAS20DX Canister Vacuum
In run mode while holding down the handle to move forward the unit moves forward and stops. It will eventully start moving forward again but stops again. This repeats the same way no matter the what the variable speed is set at
Posted by mark_vergari on
  • mark_vergari Jun 15, 2011
    Thank you for your reply. We are looking into both of your suggestions however I wanted to share a couple more comments. I did not mention that while this problem occurs the scrub head still turns and the vacuum still works while the unit starts and stops. I assume if it was a power problem that those two items would stop working as well?
Rossiel Gomez
  • 517 Answers
Good day boss Mark!!!
I suggest you check the power indicator if it does not stop ,
if that so, maybe the problem is on the motor.there is a possibility
that the supply of the motor is loosen or worse there is a worn out gear within the motor.
If you find it loose please fix it..you can solder it.
If worn out gear..please replace it for a new one.
And also put an oil to the parts needed it.
If you can't find a gear to replace for the worn out gear
find for a whole parts or much better to buy a new vacuum
because it is more expensive to buy a new whole motor.
I hope my suggestion helps you...Thank you...Please don't forget to rate and testify if I solve your problem if you have more time...
Posted on Jun 16, 2011
bonifacio gomez
  • 1,238 Answers
Good day!
that problem is usually causes of power failure on your machine please try to check the power source if have a loose connection..Please fix it..
Also try to check the power switch normally the power switch got a loose contact if it is defective..
try to check it and replaced it if necessary..
Thank you and good luck.
Posted on Jun 15, 2011
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
Self propel not working
Make sure the replacement belt was the right one/size.
Make sure the self propelled is on at the handle. If you replaced the flat belt and it still pushes hard the most common problem is a broken power drive cable or actuator arm. Put the handle down and move the power drive handle forward and backward. If it moves freely watch by the headlight for the cable to move the actuator at the base. If the cable is in tact it should move the actuator. If it is broken the actuator will not move. If the actuator is broken the piece of plastic holding the cable will let the cable slide or it may be broken off completely. Replace whichever is broken.
If the cable system is ok and the belt is correct you may have a bad powerdrive assembly. I will include links to correct replacement parts.
Actuator
http://www.vacuummedic.com/product.php?id=363
Cable
http://www.vacuummedic.com/product.php?id=362
Belt
http://www.vacuummedic.com/product.php?id=6
Good Luck!
Aug 23, 2012 | Hoover U6446-900 WindTunnel Bagged Upright...
Bissell 1970 quicksteamer water runs out of clean water tank
Try re-installing the handle. Remove the screw on the back of the machine and pull up on the handle. Once the handle is removed pull the trigger to make sure the plugger on the end of the handle moves up and down when the trigger is pulled. If the plunger is moving reinstall handle and test. If the plunger is not moving you may need a new handle.
Sep 01, 2010 | Bissell 1770 Quicksteamer II Upright...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Drive not working on my hover sweeper handle seems very loose
How to Change Actuator on Hoover Self-Propel vacuum Cleaner - Step by Step This is a notorious problem for the Hoover WindTunnel Self-Propelled Models. What happpens is that the handle of the vacuum that controls the transmission is controlled by an actuator arm that is attached to a cable that runs down through the machine. The poor design of this self propelled system is design in such a way that if you pick up the vacuum using the handle (this is natural way to do it, I'm guilty of this as well), it puts too much strain on the actuator arm that controls the self-propelled mechanism, and causes the nut, washer, and screw to strip right out of the actuator arm. This explains why your handle is so loose. You may verify this by looking at the gap between the upright body, and the lower agitator housing, right where the vacuum pivots when you step on the handle release pedal. You should see when you move the handle up and down that the cable and nut are the only parts moving, and you should be able to see where the nut did sit inside of the actuator arm before it was stripped. The good news is that this is a relatively inexpensive part, and the repair is really not that difficult.
I will explain step by step, and include pictures so that you may see how to replace the part that's broken.
Always be sure your vacuum is unplugged from the electrical outlet before performing any kind of service!
Tools and materials:
Torx bit or driver size T-25
Flat blade screwdriver
Phillips screwdriver
Actuator arm – Hoover part number 43143046
Here's the picture of the part that probably needs to be replaced.
Step 1. Place your vacuum cleaner upside down with handle resting on the floor and brush roll housing resting on a work bench.
Remove 4 screws from rug plate and set rug plate aside.
Step 2.
Remove power drive belt, brush roll belt and brush roll.
Step 4.
Remove 6 screws as shown. Also remove duct hose cover and small plastic section that was under brush roll in upper left corner.
Step 5.
Place vacuum right side up on top of work bench with handle all the way back. Using a flat blade screwdriver; gently pry the top cover away from the bottom housing in the area shown by(#1) arrows. Leave the 2 adjustment knobs(#2) in place.
Step 6. If the self-propel adjustment cable HAS NOT broken away from the actuator arm, proceed as follows; mark the position of the cable(#1) in relation to the cable retainer with a black magic marker to avoid having to readjust the cable position. Remove the screw(#2) (usually a Torx T-25 size screw) and cable retainer. Next, using a flat blade screwdriver; slide the ‘C’ ring (#3) off the metal post. Bend the metal bracket up off the post just enough so you can lift the damaged actuator up and off the post. Slide your new actuator arm back over the metal post. Slide the ‘C’ ring back over the post.Lock the self- propel cable back in place with screw and retainer. Test to ensure the power drive is adjusted correctly; CAUTION, YOU ARE ABOUT TO COME VERY CLOSE TO MOVING MACHINERY, NO NECKTIES, NECKLACES, LOOSE SHIRT TAILS,UNACCOUNTED FOR TOOLS OR CLUMSY FINGERS ARE ALLOWED FOR THIS NEXT STEP!!! Reinstall the power drive belt, plug your vacuum cleaner back in and turn it on. Check to make sure the handle is in the neutral position; observe that the power drive is NOT moving. Push the handle slightly forward. You should see the power drive wheels move in the forward position. Pull the handle back, you should see the power drive wheels move in the reverse position. Some finer adjustment may be necessary.
If the power drive cable has broken away from the old actuator; just try to get the new actuator arm as straight as possible. Using the handle and while observing the cable moving back and forth through the retainer area; move the cable all the way forward, then pull it all the back, try to gauge where the middle of the forward and reverse position would be and lock the cable down. Perform testing procedure as in previous paragraph. Again, some fine readjustment may be necessary.
I hope that this was helpful. I'm am 99% sure that this will fix your problem, but if for any reason it doesn't, please feel free to use the Clarification Request Form here on Fixya, and explain why this didn't work. Please feel free to logon to our website, http://www.govacuum.com/ if you need any parts for your Windtunnel.
If you can't find a particular part, more then likely we have it, just feel free to give us a call.
If this repair was hepful to you please be sure to rate the repair as helpful by clicking the Thumbs Up Icons in the top right hand corner.
Thanks again,
Chris J.
GoVacuum
Mar 27, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush bar on Dyson DC07 clic
Not sure if I understand what you mean, but I'll try... I guess the "button" that you refer to is the clutch knob that's located on the side of the base. It has three positions: manual off, auto off and auto on. In manual off, the brush bar is always off. In the auto position, the brush bar should be off when the machine's handle is upright and automatically turn on when the handle is lowered.
If you've got the knob in the auto position but the brush bar does not rotate when you lower the handle, then there's a problem with the clutch unit and you will almost certainly need professional help. It is possible for the keen amateur to service or replace the clutch unit, but it's quite a job.
If you opt for a professional service, be sure to get a firm quote as it may cost more than the machine is worth to you. The part's not cheap, and there's a fair amount of labour involved.
I hope this helps. If not, please reply with more details and I'll try again.
Jan 12, 2010 | Vacuums
My Roomba will not move forward. It will try and spin itself and then try to move forward but then spin itself again until it stops and beeps. I tried cleaning the whole unit but it still is unable move...
Hey
is it 5xx Roomba ? is it 9 beep that it sounds ?
Please look for other same problem posted here ;-)
You are probably facing a bumper sensor issue.
Try to clean the bumper first and if this goes on, either call iRobot service, or
take a look at this page for the step by step 9 beep fix.
Have fun
Avi
Aug 03, 2009 | iRobot Roomba 530 Robotic Vacuum
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Powr Flite PAS20DX Canister Vacuum Logo
Top Powr Flite Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
