SOURCE: Canon A95 gone dead
Canon customer support will tell you what exactly what is going on[or not] I suspect a circuit failure- if the camera is out of warranty then a new camera will probably bt the answer.
SOURCE: xti wont power up
Well, I'm the 12th user. Just wanted to post that my camera had the same issue at 13 months old. I'm about to take it in for service under warranty. Hope I don't run in to problems getting it taken care of! This site was very helpful in helping me determine the issue.
SOURCE: Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
This error is either a flash circuit or a lens error. One of the two need replacement.
SOURCE: I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
