I hope I can help!
This is something that I really cannot explain how to do in a single post. I would recommend that you start reading W3Schools. Basically, there are a number of ways you can create a website. There are many program out there than can do most of the work for you, such as Dreamweaver (a more expensive product). You can also use pre-made layouts such as webs.com. If you really want to learn how to custom-make your own website from the ground up, you will need to go through W3schools, or something like that. You will want to learn html, probably css, and javascript. These are a few of the basic programming languages that make up the backbone of the web. W3 should also bring you through purchasing a domain name and such.
I hope that helps!
Basically there are number of ways you can create a website. It depends on you what type of website you want.
You can build a website by learning from online tutorials. I found a great tutorial. You can check out simplewebsitetutorials: How to build your own website, it is a simple practical guide where you can learn from the basics and through this tutorial you can build a website very quickly and easily. Hope it helps you!
First You need to register the Domain name,then You need to host the site,finally designing it in best way ,attractive way...Now website will get ready.....
But the coding for the page and data base creation is your manual process,it's important...
You need to choose the best registrar and hosting provider...You can register the Domain name here
Whoisxy i registered the Domain name there
