Cars & Trucks Logo
Posted on Aug 19, 2008
Installing brake pads on 2004 ram 1500
Any tricks to know on how to reinstall brake pads on my ram
A
Anonymous
Also be sure to either have your rotors turned by a professional or buy new rotors. They wear grooves and warp over time and if not machined back into a smooth flat surface it will cause a shaking and uneaven braking problems and will greatly increase the wear on your new pads. New rotors are not that much but getting them turned at a parts store usually costs around $5-10 each. Also not turning the rotors may viod any warranty you have on the new pads.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2808
Points
Get a c-clamp and take one of the old pads and place on the caliper piston. screw the clamp till the piston is fully seated. make sure to apply pressure evenly to not damage the seal.
do one side at a time or you may cause the other sides piston to pop out of the caliper. if both sides are already disassembled, you can take the old pads and place them in the other caliper, so the piston movement is limited.
after the piston is seated, put the new pads into the brace, it should be fairly obvious where they go. put the caliper on the bracket and install and tighten the bolts.
I would suggest buying a repair manual from an auto store, especially if you have never done a brake job before.
hope this helped.
I need to know what is wrong with my dodge ram 1500 . When I brake the truck squeals and its not my brake pads cause they look like new .
Did you install Dodge Replacement pads or aftermarket? With the size of the rotors and pads on your Ram it is not uncommon for aftermarket pads to have squeal. Did you install and use the anti-squeal material that should have come with the pads?
1helpful
2answers
1999 dodge ram 1500 brakes
Hello......on the Dodge ram....either a 3/8th inch allen wrench or a half inch socket removes the 2 bolts.....I've seen 'em both ways....I hope this was helpful......Let me know what happens......PEACE......
1helpful
2004 Dodge Ram 1500 pickup speedometer and odometer quit
I am having the same problem. I replaced the speed sensor on the rear diff. and the problem went away but when i started it the next day the problem came back. If you figure it out let me know.
1helpful
2004 dodge ram 1500 slt wiring diagram for hooking up a brake controller for a trailer
Try http://www.etrailer.com/faq-wiring.aspx. If it is factory installed, there should be a plug in next to/behind the parking brake pedal... at the top. Not easy to see or get to.
Removing brake pads from 2004 dodge ram
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
I am changing my rear brakes on my 2004 RAM. Is
Should just need a pair of pliers to push the piston back. Soak the rotors with PB blaster or similar overnight, or if replacing smack the **** out of them.
BLEEDING BREAKS ON 2004 RAM
you need someone actually in vehicle after you put the brake pads on start at one side have them pump the brake then hold down tight calipers until they are on rotor then do it again and again by then it should not be soft go to the next side and repeat the process
How do I get the brake pads off a 2004 Dodge Ram?
Take your tire off, unbolt your caliper which is holding you pads to the rotor, and then just take a flat head screw driver and lightly take the pads out of the clips but if your replacing the pads its always a good idea to replace the clips.
04 dodge ram 1500 HEMI's new brake pads won't fit
what you need to do is line clamp brake hose so you dont push dirty brake fluid back into your system..(you can use a pair of needle nose visegrips if you dont own an actual line clamp) loosen bleeder at this point, remove caliper from attatching bracket, with old pad still installed next to piston use a big C-clamp to compress piston, just make sure clamp is centered and compress slowly allowing brake fluid to escape through loosened bleeder... once compressed tighten bleeder and install caliper and pads remove lineclamp....******NOTE******* no need to bleed the system cause of lineclamp procedure... Make sure upon reassembly you use plenty of brake lube on all sliding caliper parts...Good Luck
Brake pad replacment on 2004 Dodge Ram 1500
Remove two bolts holding caliper on and pull up as hard as you can on the caliper. Wiggling back and forth at the same time helps.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
