Question about Casio FX991MS Scientific Calculator
How can I find :11^27mod 29 using my CASIO fx-99IES
Posted by soory80 on
John Watson
  • 37 Answers
11^27 = 13,109,994,191,499,930,367,061,460,371 which is 29 digits long.
You can get this result from the Windows calculator (scientific view) by entering 11 and then pressing x^y 27 = . Then use Mod 29 = to get the result, which is 8.
Unfortunately the Casio fx-991ms (as with most other calculators) doesn't have nearly enough digits to cope with this type of calculation. You therefore need to split the calculation down into more manageable chunks, as follows, which works on most calculators:
First calculate 11^3 = 1,331 and work out Mod 29, which is 1,331 - 45×29 = 26.
Then calculate 26^3 = 17,576 and work out Mod 29, which is 17,576 - 606×29 = 2.
Finally calculate 2^3 = 8. Since this is less than 29, it is also the final answer as confirmed above.
This method can be used with any power number that can be factorised into numbers that don't cause the available digits of the display to overflow. In this case 27 = 3×3×3 so each step involves cubing the previous answer.
Posted on Jul 05, 2011
How can I change the threshold for scientific notion rounding in normal display mode on my Casio fx-9750GII.
[PDF]fx-9860G Series_fx-9750GII_fx-7400GII_Software Ver. 2.0_Eng - CASIO
support.casio.com/pdf/004/fx-9860GII_Soft_E.pdfThe contents of this user's guide are subject to change without notice. ... For full details on availability in your area, contact your nearest CASIO ...... The calculator normally displays values up to 10 digits long. Values that exceed this limit are .... The fx-7400GII and fx-9750G II are not equipped with a Math input/output mode.
SOLVED: Scientific notation on the casio fx-9750GII - Fixya
www.fixya.com/support/t20210775-scientific_notation_casio_fx_9750gii
Sep 20, 2013 - Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below. Scientific notation on the casio fx-9750GII
Mar. 13, 2017
SOLVED: How do i turn off the scientific notation
Mar. 30, 2015
Using Scientific notation on the casio fx-9750GII
Oct. 5, 2013
Casio FX-9860G Graphic Calculator Scientific ...
Oct. 18, 2011
More results from www.fixya.com
How can I use scientific notation on casio calculator? ' Socratic
https://socratic.org > ... > Correct Use of a Scientific Notation on a Scientific Calculator 7 days ago - Most scientific calculators have a button EXP ...type in a number, press EXP , AND then you asked to input the exponent as a power of 10 .
videos
casio fx 9750gii scientific notation Google Search
Jun 18, 2018 | Casio Computers & Internet
HOW DO YOU TURN IT OFF AND START OVER
You could always remove the battery and start over. The procedure for removing the battery is on page 29 in the attached manual.
Good luck,
Paul http://support.casio.com/storage/en/manual/pdf/EN/004/fx-300ES_PLUS_EN.pdf
Mar 08, 2016 | Casio fx-300ES Calculator
Could you please help me .. Is it possible to calculare irr with casio fx 82 ms? Thank you very much
Internal Rate of Return (IRR) Calculation Using Casio MS ...
? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
Discounting Basics on Casio fx-991ES and fx-82MS ...
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
Jan 10, 2016 | Casio FX82MS Scientific Calculator
How to do interpolation in Casio f2f-4800p?
Interpolation mannual in fx-4800P - Fixya
www.fixya.com/support/t22818601-interpolation_mannual_in_fx_4800p
Jan 11, 2014 - interpolation mannual in fx-4800P - Casio Rare Vintage Scientific question. ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
interpolate how can interpolate linear regression by casio ...
www.fixya.com/support/t22818666-interpolate
Jan 11, 2014 - interpolate how can interpolate linear regression by casio fx-4800P -Casio ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
how to perform linear interpolation manually and on casio fx ...
? 6:39
https://www.youtube.com/watch?v=rCVM6RWMjQ4
Jan 7, 2015 - Uploaded by Yabets Jab
In this video you can simply understand how to find a value of a given missing number in a table on Casio fx ...Missing: 4800p
Linear Regression on a Casio calculator - YouTube
? 6:25
https://www.youtube.com/watch?v=OGmHagjZPjg
Oct 31, 2012 - Uploaded by cpobyrne1
How to perform a linear regression on a Casio scientific calculator. Example uses a ... A Casio fx-83WA calculator is used for the demonstration. .... Lagrange Interpolation Easily Explained on Casio fx-991ES Calculator!Missing: 4800p
Jan 05, 2016 | Casio Office Equipment & Supplies
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How to recover algebra fx2 programs password?
Standard Casio calculator programs have codes that you can find on Planete casio, a site in French.
Here is the link
http://www.planet-casio.com/Fr/forums/topic1048-1-Mots-de-passe-pour-graph-60-ou-65-%28plus%29.html
As to recovering the password to a program you created, you will have to try hard to remember. Or opening the file with some file editor.
Nov 02, 2013 | Casio Algebra FX 2.0 Calculator
Forgot program password
Here is the link
Please is there any calculator by model fx 911 ES
Casio has a scientific calculator with Model FX-991 ES. It is sold in North America, and maybe in other continents. You can find it at Staples/ Bureau en Gros stores for around 29 CAD.
Sep 06, 2011 | Casio FX-115ES Scientific Calculator
How to calculate 17^23mod55 in casio scientific calculator fx-991MS?
Using the Windows calculator in scientific view, we get:
17^23 = 19,967,568,900,859,523,802,559,065,713
which is 29 digits long, ie much longer than the capacity of most calculators.
Because both 17 and 23 are prime numbers, it isn't possible to simplify this calculation, so you will need to use find a calculator that has sufficient capacity to be able to handle numbers of this length.
The xnumbers add-in for Microsoft Excel can also be useful for this sort of calculation (do an internet search for it).
Using the Windows calculator, MOD55 of the above number is 18.
Jun 30, 2010 | Casio FX-115MS Plus Calculator
360 degrees divided by 29 spaces
What do you really want to do? 360/29 gives 12.4137931 degrees. Is it not 360 divided by 30? That looks more common, and the result is 12 degrees. That is what you get if you want to inscribe a regular 30-gon in a circle.
Feb 21, 2010 | Casio FX-115ES Scientific Calculator
Casio FX991MS Scientific Calculator Logo
792 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
