Microsoft Xbox 360 Console Logo
A
Anonymous Posted on Jun 13, 2011
I HAVE AN OCTOBER 2008 XBOX AND A 150W 12.1 AMP POWERBRICK FROM A NEWISH XBOX . PLUG ON POWERBRICK WILL NOT FIT SOCKET ON XBOX
Anonymous
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Jun 13, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
14630
Points
210
The power cords for the Xbox 360 and the Xbox 360 slim have different shaped plugs. If the plug you are using is not fitting it is likely that you have purchased the incorrect cord. If this is the case you will need to purchase a new cord.
When you purchase your new power cord make sure that it is designed for the original Xbox 360 NOT the Xbox 360 slim.
2008 dodge caliber 1.8 L. Pic of replacement shows nut type ring to fit deep socket. Mine has plastic ring. Part of socket assy for wiring plug. Coolant temp sensor.
I would ck again, you might just be seeing the plastic housing for the wiring connection and missing the actual brass nut directly below that housing, place the socket slightly over the housing and ck. the fit by attempting to turn the socket by hand in either direction. If you experience a loose fit where the socket turns just a little, slip the socket down until it seats against the base of the sensor firmly and try turning again. I would expect the socket once it is seated all the down onto the nut you will feel no movement when attempting to turn by hand.
1helpful
Spark plug socket dont fit dodge ram
I think your vehicle takes a 15mm or 16mm socket. Normal spark plug wrench will not work. Visit your local Parts Store for more information. Have them show you a replacement plug for your truck and see what socket fits it.
Good Luck.
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
2helpful
When i turn my xbox 360 onto stanby the powerbrick light is on orange,but when i turn my xbox console on i get 3 red rings and my powerbrick light is on red?
Hello there
From what you have said it sounds like you have the RROD - 3 LIGHTS
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
What is wrong when the red light is on in your xbox 360
Either
1) Overheating,
2) Problems in GPU,
3) Problems in powerbrick.
Why shud i use a 230W supply on om my XBOX 360? is it better than the 175W and the 150W?
The more amperage you have on the 12 volt rails the more power you can draw from the power supply. For an xbox 360 I don't see any reason why you would use a non-standard power supply unit there really is no gain using a computer PSU on an xbox 360 unless you broke your factory PSU and then you could rig a computer PSU to it but your better off not trying unless your really good at electronics.
Xbox my power cable won't fit into the back
I never heard of this, it is probably up-side down. Or perhapes you forced it in, while the wrong way which make's some plastic tear off, so if you notice it, your might need a new powerbrick/AV cable
I get a red light on my powerpack
i think that means that the connection between the power brick and the xbox isnt working, either your xbox needs repair or you need a new power brick, ask a friend with a 360 if you can borrow theirs and also their wires for the powerbrick and if it works then YOU need a new powerbrick and if it doesnt then your xbox is broken
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
2answers
No power!
Duke, take a look at the big 'powerbrick' that powers your xbox, on the front of it there will be a small LED, it should be red/orange if your xbox is turned off. If you see NO LED light then your powerbrick is no longer functioning.
If you DO see a LED, then its likley the Xbox is at fault.
Hope this helps!
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
