Hi!
watch this video to see how to fix souls which came off :
https://www.youtube.com/watch?v=QDcncVxwOVk
https://tgw.onl/digitalocean/ https://tgw.onl/siteground/ https://tgw.onl/ipage/
The best method for repairing a shoe with a hole or that has become torn:
Make certain that your shoe is clean and fully dry and roughen the surface for better adhesion. Seal holes or torn area from the inside with duct tape or similar before applying the shoe glue to the outside.
Seal the hole or open seam with a bead of the adhesive.
Spreading the adhesive is the hardest part because it is sticky. (A good trick to spread the glue around the surface of your shoe is by using an ice cube. The adhesive won't stick to the ice and the glue will flow evenly where you need it. The cold temperature of the ice also helps to make the glue set.)
Once the glue is fully dry remove the piece of duct tape from the inside of the shoe.
Any excess material that needs to be removed can be cut off or removed with paint thinner.
These shoes seems like it may be possible to reattached soles with something like gorilla glue, but it will probably never stay. HERE you can get shoe glue which can help a lot but may its never a guaranteed. You best bet is prevention next time. Obviously whatever made the soles come off last time don't do it again. Also try protection like a waterproofer. HERE is a good waterproofer which can help from water getting in between the shoe and the soles. Hope this helps.
