Question about Amana Washing Machines
My Amana Stainless Designer Series Heavy Duty Super Capacity Plus washer LWM353W is leaking oil? Is the repair worth it; or should I buy a new one?
Posted by acnegrete on
5 Related Answers
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: I have a Kenmore Heavy Duty 70 Series Extra
If this is a Kenmore Top Loader washing machine, it sounds like you have a broken motor coupling. The washer filling and draining, but no agitation and spin are common symptoms with this problem. There may also be a rattling or whirring sound as the drive motor attempts to engage.
NOTE: If the washer drains, the drive motor is working. This drain pump on this washer is driven by the drive motor.
The motor coupling is located between the back side of the drive motor and the gearcase (transmission). The coupling is used in place of a drive belt, which is why this type of washer is referred to as a "direct drive". The following link explains how to access and replace the motor coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included with the link and can be purchased at appliancepartspros.com for about $11. I have included an illustration of what the coupler looks like below.
If the motor coupling is intact upon inspection, the other source of no agitation and spin would be the gearcase. The gearcase on these washers is fairly simple to replace. If you narrow it down to a failed gearcase, the next link explains the steps for replacing one:
http://www.fixya.com/support/r699497-replacing_gearcase
I could only find your model number referenced at repairclinic.com. The gearcase on their site lists for about $160 and is listed as item 423.
I could not find any exploded view diagrams of your washer, but the majority of all Kenmore and Whirlpool top loaders are designed with the same direct drive system. You can purchase a Direct-Drive Repair Manual at repairclinic.com for about $20 (Item number 1170635) if you need a guide for reference.
If you have any questions about this repair, or require additional assistance, please let me know. I hope I've given you enough to work with in trying to narrow down the cause of your problem.
Posted on Sep 29, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
Anonymous
SOURCE: I have an admiral heavy duty super capacity plus 2
load lite, and if the problem still is there let run empty a couple of times, if there is still a problem it is off track and a professional needs to go inside of it you can do it yourself but not recommended so call a pro!!!
Posted on Apr 21, 2010
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
Removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
350 people viewed this question
Top Amana Washing Machines Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
