Does FIFA 11 crash on your
Windows platform? If you are suffering with FIFA or any other game
crashing, this article would teach you about the factors causing games
to crash along resolution steps to help you fix issue quickly and quiet
easily. Common Causes: Below is outlined detail to fix FIFA 11 crashing! Update your Video Card Driver To play FIFA 11 without crashing, you
should have latest device drivers. If you are unsure about your video
card vender, you can follow the steps given below to learn about your
vender. Repair Registry FIFA 11 crashing can be due to corrupted
entries in the registry database of operating system. Congested
registry entries can also cause applications to crash. To solve this problem, download and install system utility software on your computer. Scan and repair registry. Update Microsoft .Net Framework To play FIFA 11 without crashing, an
updated .net framework should be installed on your system. If your
.net framework is outdated, you should uninstall it and download
latest version. To uninstall Microsoft .net framework, follow the steps
given below. Reset Audio Sampling Rate Another solution to the problem FIFA 11
crashing is to set your Audio Sampling Rate to 24 Bit 44.1 kHz. Follow
the steps given below. Optimize your PC Optimizing your PC is helpful in
increasing the performance of your system. Junk data in system not only
freezes applications but it also causes serious problems such as FIFA
11 crashing. To quickly fix FIFA 11 crashing
on your system, scan your registry using authentic registry cleaner and
increase speed of computer using PC optimizer. Here is Intel Software
Partner, RegInOut system utility software that is widely used to fix
registry corruption and can boost the speed of your game.
I don't quite follow the problem but, you have a low end card and maybe the game is too demanding for it. Are you having problems with crashing? Have you updated your driver? You can update the driver here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Product Type-GeForce
Product Series- GeForce 5 FX series
Product-GeForce FX 5500
Choose your operating system, language and click search.
You will want to uninstall previos driverbefore downloding new.
