Whirlpool Washer WTW5800SW cold water option will not fill on any wash cycle, but will on rinse cycles. Hot water not turned on; I always use cold. Just realized that cold water comes in fine for wash cycle when I turn the dial to cool, warm or hot, but not when I put the dial on cold. Guess I'll just leave it on one of those options, but something evidently is up with this. Thanks
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
