check your hoses if they are switched around..............hot water should be on the left and cold should be on the right...............if all is good, just try and switch it around and check.............the timer should not be a problem for water temps...........usually its the solenoid vavle or the temp switch.............
feed back would be good if this helps anybody........
if anything just message ................
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
It sounds like you have the hot and cold water lines to the washer reversed.
Try turning off the tap for the hot water then setting the washer to just cold wash and then hot washif you get nothing on the cold and cold water when set to hot they are probably reversed. Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
