Question about Dewalt Dc411 18v Volt Battery Cut Off Tool Grinder Saw
Hi, i have a dewalt dc411 cutting tool, i bouth it in US.Batterys are new ( charged 10-15 times only, DC9096) My battery time is very low, about10-15min cutting/battry. Is this normal?
Posted by wendtm on
Jeff Harris
    New Friend:
  • 81 Answers
Yes it is . I have one too and the cut off tool takes more amps than a drill or flashlight or saw. Different tools take up different amperage,so it will vary in the amount of time the battery will last.
Posted on Jun 12, 2011
Dewalt 18v XRP Problem Powerline
It sounds like you have a defective battery. I would suggest contacting one of our Factory Service Center's to see if your battery is still within warranty. Please see the link provided. You can also give as a call at 1-800-4DEWALT. DEWALT com
Mar 17, 2015 | Dewalt 18v Xrp Battery Dc9096
"Problem Powerline" flash code appears when I try to charge a particular XRP battery in any of my three charges yet all my other batteries charge fine.
Mar 17, 2015 | Dewalt dc9096 xrp battery 18v
How do i close the chuck on a dewalt dcd950
The DCD950 was DeWalt's worst chuck design. This chuck has no chuck screw, they loaded the spindle with locktite and put them on. Consequently, the chucks are nearly impossible to remove. DeWalt made a tool for this purpose, but it costs almost $90 - the only alternative was to replace the gearcase assy but they just made it obsolete, no longer available.
There is a conversion kit but the problem remains, you still need to be able to remove the old chuck.
We have used a metal cutting saw to cut the chuck off - about the only thing that works Conversion Kit N422782 for DeWALT Power Tool eReplacement Parts
Sep 25, 2014 | Dewalt Dcd950 Hammer Drill Uses Dc9096 Or...
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 | Drills
I need to find out where to buy the power terminal fo a 18v dewalt battery
I've been working on cordless tools of many brands for years and there are no individual parts available for batteries from any manufacturer nor any aftermarket parts retailers that I have ever found. Usually if you need these types of parts you have to scavenge them from other batteries.
Mar 04, 2012 | Dewalt DC9096 18V Xrp Battery Pack
Batteries dont last very ling
If one contimues to use the pack after the tool starts to slow down one cell in the battey depletes and then reverse charges and then shorts, After that, that cell will not charge and the battery will only produce the rating minus 1.25 volts from that point. Unless you have the battery rebuilt it will never again take a full charge. Either replace or have rebuilt to solve the problem.
Aug 30, 2011 | Dewalt DC9096 18V Xrp Battery Pack
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Dewalt Dc411 18v Volt Battery Cut Off Tool Grinder Saw Logo
181 people viewed this question
Top Dewalt Saws Experts
efs_perpends
efs_perpends
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
