Question about Saitek X52 Flight Control System
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
    New Friend:
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
Posted on Mar 20, 2013
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: My joystick will not respond.
you have to plug the round tipped courd into the slot in both controllers, connecting both. you only plug one thing into your computer and that is the usb cord built into the throttle control.
Posted on May 09, 2010
mpcheeseman1
mpcheesman1
  • 1400 Answers
SOURCE: I bought a new X52
Hello
Go to control panel.devices and printers.Find your joystick.right click on the icon then select game controller settings.then properties then settings then calibrate.
Once at calibrate follow the instructions on how to calibrate.
Also you may want to try shutting down your pc.Unplug your joystick.Restart the pc,once started plug your joystick back in, and let windows reinstall it.
Hope this helps
Thanks for using Fix ya
Posted on Feb 06, 2011
X52 pro mouse function
How to bring up other e-mail that not opened a while: [email protected] ?
Jan 13, 2014 | Saitek X52 Pro Flight Control System Game...
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
Jun 14, 2011 | Saitek X52 Flight Control System
I'd like to use a Saitek X52 joystick/throttle system for Dark Void. Is there any way to do this?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Unfortunately You can't do this, because Saitek X52 is not compatible with Dark Void serials, checked on main steam website.
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Capcom Dark Void for Windows
Nov 16, 2009 | Saitek X52 Flight Control System
Lost the interconnecting cable, need help with replacement
It's a Male/Male PS/2 Cable. You have a couple of options:
1) Make it yourself. Find a couple of old PS/2 Mice, take em apart, tie em together and heat tube it OR
2) How can I get a Replacement Cable for my X52 Units?
Due to high demand, we cannot guarantee replacement cables for the X52 Pro. However, if you would like to request a cable please send your details to [email protected]. We will process the request and inform you as to the availability of the cable.
May 03, 2009 | Saitek (PS28) Joystick, Throttle
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
X52 calibration
have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Mar 03, 2008 | Saitek (PS28) Joystick, Throttle
Saitek X52 Flight Control System Logo
4,236 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
