Video Game Consoles & Games Logo
Posted on Jun 12, 2011
Controller doesnt connect to xbox 360 - Video Game Consoles & Games
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 12, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
314
Points
13
Http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx#expandoContent1If this doesn't work, the only option I can think of is purchasing a used controller and repeating the process above with the recently purchased controller. A safer and cheaper option, however, would be purchasing a used wired controller. There wont be as many problems.
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
1helpful
WHITE WIRELESS CONTROLLER FROM X BOX 369 DOESNT CONNECT WITH THE NEW BLACK XBOX 360
On the front of the controller there is a small circle button, there is also one on the xbox console. Make sure both the controller and console are on, and press both the circle buttons at the same time and it should connect.
My xbox 360 controller start doesnt work and it does not turn on when i put a new battery in
have you tried adjusting the terminals for a better connection for the batteries
2helpful
I have an xbox 360 and my controller won't connect but it will turn on the xbox 360 when you hold the button in the middle but still won't connect and i have tried a million time to connect the controller,...
it could be flat?, charge it or get new batteries and try, if that doesnt work you have to hold down the little button at the back of the controller and press the button next to memory unit b on the console
goodluck
1helpful
My Xbox 360 controller is not flashing when I try to connect
make sure you press the find button on the 360 and the one on the controller.
on the 360 it is a small circle bellow the disc tray and to the right of the two memory slots.
on the controller it is on the top its small and circlular with three semicircles near it.
if it still doesnt work then try to synce up with another persons console. if the controller still doesnt then you need a new one. if it does then use their controller to sync up with your console. if it still will not sync up with YOUR console.
then call
1-800-4MY-XBOX
1-800-469-9269
1helpful
360 Controller Won't connect
the problem may be that they arnt syncing correctly, i had this problem and i was a ble to fix it, first you have to turn the console on, dont turn the controller on, hold the xbox's sync button for about 30 seconds, now turn off the console, remove all wires from the xbox, and from the mains power, after about 5 minutes plug it back in first click the xbox sync button then the one on the controller, this should work, if it doesnt call xbox customer support on 0800 587 1103 (UK) or 425 635-7180 (US)
Xbox 360 controller wont connect
Try replacing the batteries. I think you would have tried that but go ahead and try again. If you are new with 360s try to sinc the controller with the 360. Hope that all works.
dont try tearing your controller apart to try to get it to work. If it doesnt work take it back to the store you got it from and try to get your money back.
If all of that doesnt work............. buy a new controller.
2helpful
Controller
you have to press the connection buttons, one on the controller and one on the xbox 360, the one on the controller is located on top by the triggers next to the cartridge insert port right by the left button, it has 3 wavy lines next to it, when you press it, the controller will light up and go in circles. After that quickly press the button on the xbox 360 located under memory unit A, to the left of the disc eject, then the xbox 360 lights will go in a circle then automatically connect. If it doesnt work at first, try it again, but quicker.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
