Question about Sharp MX-2700N Color Copier
What does code DK indicate on an MX-2700N? - Sharp MX-2700N Color Copier
Posted by skypilot13 on
Sreelal Devadas
    New Friend:
  • 66 Answers
IT MEANS YOUR BLACK DRUM AND DEVELOPER NEEDS REPLACEMENT, IF NO PROPBLEMS ARE THERE IN YOUR CPY QUALITY YOU CAN RESET THIS BY PRESSING #*c* BUTTON RESPECTIVELY WITH NOT MUCH TIME DELAY IN BETWEEN THE KEYS, THEN MACHINE WILL ASK FOR MAIN CODE THEN PRESS 2 AND 4 THEN PRESS START THEN YOU CAN SEE THE DRUM AND DEVELOPER COUNTER RESET SELECT THAT BLACK DRUM AND PRESS OK THEN DELOPER ALSO LIKE THIS THIS WILL RESOLVE YOUR PROBLEM, IF ANY QUERIES FEEL FREE TO CONTACT AND VOTE AND RATE THIS AFTER GETTING YOUR PROBLEM RESOLVED.
Posted on Jun 13, 2011
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
Sharp mx 2700n tc2 belt day
The second transfer belt is the rubber belt assembly which is inside the right door. The maintenance alert "TK2" indicates that the belt has gone past its' useful life and needs replacement or rebuilding, there is a rebuild kit available.
May 28, 2014 | Sharp MX-2700N Color Copier
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
It says maitenance required. Code:DK, what does that mean?
The black drum unit has reached the end of it's lifespan.
Oct 15, 2009 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
246 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
