Still looking for a solution to the Error 1305. I've tried all the suggestions I've found and nothing has worked. It's pretty bad to have a piece of software for months that you can't use.
Tried hitting Retry till I'm blue, no help.
Changed the colors to 16 as was suggested, no help.
Turned off UAC Control, restarted in Safe Mode, as suggested by the Punch software Tech Support, no help there either.
Tried to copy CD contents to hard drive but the read failed.
I think we're down to guessing now. So does anyone have other ideas, suggestions, or guesses. Any would be appreciated.
morlaine
Copy all the files on the install disc to a hard drive and install the program from a hard drive. It worked for me.
Hello peter4927,
An, "Error 1305"
message mean that; your computer is unable to read the "Program Disc" properly.
This error can occur if your CD or DVD is damaged, dirty, or caused
by dust.
This can happen, if another program is "preventing your computer
from reading the "Program!"
You will also receive this error if the "Disc Drive"
is damaged or dirty.
Try cleaning the "Disc" first!
"Use a Disc Cleaner, to clean the CD-ROM / DVD Drive.
Place the "Program Disc in the Disk Drive; then "Restart the Computer!"
This will have the CD, or DVD start-up {Automatically}.
Next, you can try to start the "Disc" by using the "Auto-Run."
To do so; place the 'Disc' in the "Disc Drive Tray."
Next, [right click] on the "Computer Icon" to open the 'computer window'.
Now, right click, on the Disc Drive, and select the either, "Open, Explore or {Auto-run}.
Hopefully it will start.
Repeat each action if necessary!
"If there is anything else, you may need help with?
Write a 'comment,' I'll be here to assist you!"
"Best Regards"
