Question about Kyocera Finecam S4 Digital Camera
At the "battery empty" sign
David Lee
  • 422 Answers
Long shot:
remove battery
press and hold down the power button,
insert battery
Posted on Jun 12, 2011
  • Anonymous Jun 12, 2011
    Unfortunately it didn'work out but thanks anyway Chiingliang!
D2C01 error code
It's a non-critical shutter release error. It's nothing to worry about, and can be cleared and ignored. It happens sometimes when the camera is powered off (or the battery runs down) when it's still trying to do something.
Mar 24, 2014 | Olympus E-620 Digital Camera with 14-42mm...
My Canon Rebel Sii wont take picutres
And the battery is still ok? See the LCD display.
When the battery is almost empty, it won't be able to charge the capacitor in the flash, and the flash can't fire. The camera protects the shot, because if the flash was needed, the shot would be much to dark.
Feb 01, 2014 | Canon Eos Rebel Sii 35mm Camera Body
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Regardless of lenses,and batteries, cf cards, flash and exposure settings, when the fire button is pressed there is a small "click" and the camera freezes-no picture none of the exposure settings...
A few suggestions: The mirror lock up function has been activated. The sensor cleaning mode has been activated, doing this the camera as soon as you trip the shutter the mirror will come up and all other functions of the camera are inoperable. the mirror will stay in that position until it runs out of battery or you turn it off. The part you said about having to removing the battery doesn't make scents for this function though. Sensor cleaning is in the Custom Functions.
I know you said regardless of lenses and batteries how long do you wait before shutting the camera off and removing the battery? I know that's a question and we aren't suppose to answer a question with a question but the reason I'm asking is that the Canon 40D has a long 30 second shutter speed and a "bulb" setting. It is possible that the camera has been set to "AV" and the shutter is timing out, OR it's been turned to BULB and that mirror will stay there until the camera battery is dead before it drops. Couple things to check out before the next thing I'd think about is the amount of shutter actuation. The Canon 40D has a shutter good for 100,000 clicks/actuation. Sounds like a lot but if you are doing time laps or extended video it's very possible to blow the shutter out of these.
Dec 10, 2010 | Canon EOS 40D Digital Camera
No shutter actuation, no menu display, no autofocus.
check the battery and flash card doors. are they propely shut?
Jan 25, 2009 | Canon EOS-5D Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
Camera shuts down when the flash is opened
the flash circuit of the camera is short. the moment you switch on the flash it drops the supply voltages of the battery. you have to show it to a repairer.
Nov 17, 2006 | Fuji FinePix S1 Pro Digital Camera
Kyocera Finecam S4 Digital Camera Logo
Top Kyocera Cameras Experts
Harrie
ADMIN Canada
ADMIN Canada
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
