It sounds like you have an issue with the Anynet+ (HDMI-CEC) function. When the home theater system is connected to a compatible TV by an HDMI cable, you can sync the operations when this is enabled on both the TV and the home theater system.
You need to be turn the feature off on one or both devices. If you have another HDMI port on the TV, you could move the HDMI cable to that port. (Most TVs only have one HDMI-CEC enabled port.) Note: this turns off the audio return channel option. If you only have the HDMI cable connected between the TV and the HT-EM53C, you will need to connect another cable. Depending on the TV, this could be an optical audio cable, analog RCA audio cable or headphone (3.5mm) to RCA audio cable.
Yes it is. What you need to do is connect your blu-ray video output either HDMI or Component directly to your tv, and the audio output of your blu-ray should be connected to the digital coaxial input on the samsung system
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
There are two ways to approach this. You can either download the update from Samsung's support page, burn it onto a CD, place the CD into your Blu-Ray player and let the update load...or you can connect your Blu-Ray player to the internet and let the player download and install the update automatically.
The second approach is detailed in the HT-BD2 User's Manual (pages 46-49). It requires you to first plug a network cable into the back of your Blu-Ray home theater unit, then connect the other end into a LAN connection on your wall (or into the back of your cable/DSL modem) Page 26 of the user's manual shows you how to make the connection.
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
