Question about LG W2042S 20 inch LCD Monitor
The colour of the screen became white. There was a smoke at the back.
Posted by vpdyankov on
Eury Satorre
  • 957 Answers
1. Please try to use a different Monitor just to check if you still see the white screen.
2. If you still see the white screen on a different monitor, then your video card is affected.
3. But if you don't see the white screen using a different Monitor then, I would say that your monitor is defective, now if your monitor still under the warranty, I would suggest to get in touch with your manufacturer so that they can fix or replace your monitor.
Posted on Jun 12, 2011
Have LT 1536 . Smoke started coming out the exhaust but engine sounds healthy
Depends on the colour of the smoke.
Unlikely an engine will sound healthy emitting black smoke - excess fuel.
An engine could sound healthy emitting white smoke (steam from coolant) but not from white smoke (excess unburned diesel).
Most engines emitting blue or blue-grey smoke from burning engine oil can sound very healthy.
Dec 10, 2017 | Cars & Trucks
Thick white smoke on start-up. After engine warms up very little smoke or no smoke at all noticable. could it be the PCV valve?
white smoke indicates a coolant burning problem. most likely a head gasket and when it gets warmed up the expansion of the mating components seals off most of the leak. have a head gasket check done. burning of oil is a bluish colour not white.
Mar 11, 2015 | Cars & Trucks
How do i stop the back firing and get it started
I had possibly the same problem with my lawn tractor about a month ago... I tried removing the carburetor and cleaning it, but I always ended up pushing debris into another area and creating new problems. Eventually I just bought a new carburetor, changed the oil (some gas had gotten into my oil thanks to the problems I had with my carburetor), cleaned the spark plug, emptied the oil filter and replaced it, checked the air filter ((no oil there, phew)... and it seems to be running fine after 3 engine hours (knock on wood).
My backstory is the lawn tractor was sitting in the garage with our car for two years and not used. I prepped it for long term storage, but failed to drain the carburetor of old gas, so the old gas gummed up the works (even with fuel stabilizer). When I did get it running (after changing everything listed above) a lot of smelly white smoke kept coming out, but as I let it idle in fast speed the engine strokes became more regular and the bouts of white smoke became fewer and shorter until the smoke stopped altogether.
Hopefully this helps!
Aug 10, 2014 | Craftsman Garden
Motor is smoking in my '02 diamante, is it the gasket?
Smoke diagnostic is made by colour.
If u mean pistons head gasket,yes,it can smoke.
White (clear) water vapor.Ceck coolant level.Ceck engine oil colour by dipstick.
Black:runs rech on fuel (fuel filter/fuel lines/fuel mixture...)
Blue (whity):worn pistons rings.
Chears.
Tips:
Whity smoke before warming may be natural on cilli mornings with lot of compressure the engines just blows vapors.
Old oil/fuel residues in the exhaust tubing may blow smoke after heating the engine ,must track problem (...).
Black smoke on hitting the acceleration to the floor may be natural (overcharged) avoid sport driving style.
Sep 29, 2013 | 2002 Mitsubishi Diamante
My 1996 Nissan Maxima has a milky colour engine oil & white smoke from the exhaust.
you probably have a leaking head, water is getting into the oil. if it does not stop, then try some engine seal, and engine honey. if that doesnt work, be prepared for some major work.
Oct 15, 2012 | 1996 Nissan Maxima
I've just service my 2008 Hyundai Atos 4 days ago but now every morning just after starting it, white smoke come out. It never did this before. What could be the problem?
You need to get a better idea of what the smoke is. Is it petrol or diesel? Does the smoke linger or disappear quickly? If it is a small amount that disappears quickly it isn't likely to be a big issue.
If there is a lot of smoke get someone else to help as you reverse it out and try and see what colour the actual smoke is. The colour will give a better clue as to the problem. It could be slightly coloured as blue, black, grey or white. See the attached image for what they could mean.
May 05, 2012 | 2008 Hyundai Atos 1.1
How do i fix my acura vigor? ( check engine light}
I suggest you get one of those manuals people get nowadays to do it yourself.. My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from.
it's reliable-store com
also try manualife
Jan 25, 2018 | Cars & Trucks
When I turn it on the screen turns white. The
When I turn it on the screen turns white. The screen is all screwed up. I can still listen to music, I just can't see the menu or tell what anything says
Jul 08, 2010 | Philips GoGear ViBE Digital Media Player
Screen froze then all colours became lines then sceen went blank. shut laptop off when tried to restart sceen goes a dull white then dark please help
This is a major system failure especially display. You have to show it to one of the computer experts OR refer the matter to the company
Jan 15, 2010 | Computers & Internet
DSC L1 is not supporting 4GB memory stick???????????? Says memory card problem
    Please disregard the 'Busy' message which may appear on the LCD screen during MPEG movie recording in VX Fine mode. Recording and playback operations, as well as recorded data, will not be affected.
Sep 26, 2009 | Sony Cyber-Shot DSC-L1 Digital Camera
LG W2042S 20 inch LCD Monitor Logo
750 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
