Question about Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player
Check the impedance (resistance) on all the speakers and the speaker wires themselves.
Power up the unit with no speakers or inputs attached at minimum volume and see if it still goes into protection mode.
Most speakers should measure between 4 and 8 ohms for most systems when disconnected from the receiver.
If the unit says PROT even with no inputs at minimum volume with the speakers detached, then there's a problem with the amplifier itself, probably in the output section.
Posted on Jun 12, 2011
SOURCE: HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Posted on Apr 08, 2010
May 29, 2015 | Samsung HTC5500 Theater System
Mar 05, 2011 | Samsung HTP-1200 System
Feb 20, 2011 | Samsung HTC550 Theater System
Dec 17, 2010 | Samsung HT-Z310T Theater System
Nov 22, 2010 | Samsung HT-X50 System
Oct 11, 2010 | Samsung HTC550 Theater System
Aug 24, 2010 | Canon iR 2016i Black and White Copier
Apr 14, 2010 | Sony SLV-678HF VHS VCR
Dec 29, 2009 | Samsung HT-DB120 System
May 05, 2009 | Audio Players & Recorders
Aug 22, 2010 | Samsung 1000W 5.1-Ch. Home Theater System...
Aug 21, 2017 | Samsung 1000W 5.1-Ch. Home Theater System...
Mar 15, 2009 | Samsung 1000W 5.1-Ch. Home Theater System...
4,195 people viewed this question
