SOURCE: Flashing red icon
It must be the internal battery problem. Change the button cell that is located near the charging input jack.
SOURCE: flashing red symbol like a bowl crossed out
it means no flash card installed
no problem just switch the camera to record to tape instead
SOURCE: Icon
camcorder is just saying get this tape out of me. may be the tape, may need cleaning only or possible tension adjustments.
SOURCE: flashing red icon in viewfinder,looks like a
You need to change the battery that powers the internal clock and holds your settings. Â The slot is on the underside of the grip.
SOURCE: I have a zr100 camcorder and I have a red flashing
On page 24 of the manuel it shows the symbol that you mentioned below the battery symbol. It's labeled item 4. Which states "flashes in red when the lithium button battery is not installed, or when it needs replacing". I guess you need to check the lithium battery with a voltmeter to see if it's any good.
