Question about Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Posted by raprobst on
Kevin White
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jun 11, 2011
MasterTech
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • Whirlpool Expert
  • 86 Answers
The F02 error means the pump is not draining fast enough the hoses and pump need to be cleared of debris. Visit the link below for more information.
Whirlpool Duet Washer F02 Error Code
Posted on Mar 27, 2017
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is an F 02 that flashes on the display?
Try having a look here for what the codes mean, as well as some ways to mediate them.
Oct 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is saying f2 what does this mean
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer is not spinning all the time then flashes 02 f
Hi, f-02 means long drain. remove panel below door, pump will be in center right in front of you. Remove cap and clean out pump. Make sure you unplug washer first before you start...
Take care
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washer display shows f2
some of these models f-02 means clogged drain. check pump
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I recieve a 02 F code on my Duet front loader
02 means = Long Drain
Solution -
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What is F 2???
This is what the code F2 means for whirlpool duet washer.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is
flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes
running.
• If the above does not correct the problem replace the pump
Mar 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F02 code
F 02 means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed. Potential Causes
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
396 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
