Question about Pyramid Audio Players & Recorders
I have a pyramind sea 4600 eq and want to hook it up to a reciever
Posted by dnace1 on
LOU
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
USE THE TAPE IN AND OUT DONT FORGET TO TURN ON THE TAPE MON IN FRONT
Posted on Jun 11, 2011
Pyramid stereo graphic equalizer eq sea-4600
Well...Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Feb 14, 2014 | Pyramid Car Audio & Video
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I have a Pioneer VSX-D308 reciever and I have a EQ. How do I hook it up to this reciever?
I only know of one way to do this and here it is:
1. Plug your tape deck's output (cassette or R2R) into the EQ's "Line In".
2. Plug the EQ's "Line Out" into the Receiver's "Tape 1 Input".
3. Now plug the Receivers "Tape 1 Output" into the Tape Player's "Line In".
4. You have now made an "FX loop" for the Tape Deck. Now you just have to put the Tape Deck on "Tape Monitor".....put the Receiver on "FM"..... and turn on your favorite FM station and you will hear the FM Receiver THROUGH the tape deck's "Monitor Send" AND the EQ.............set EQ to taste....... and BINGO.......DONE!
Enjoy,
SKYNETRP
Jun 09, 2011 | Pioneer VSX-D308 Receiver
Cant hook up eq 2 kenwood vr 505 reciever
on the reciever connect patchcords from the tape out to the line in on the eq than line out from the eq to the tape in on the reciever --when you turn on the tape monitor button then the eq is engaged --enjoy
Sep 08, 2010 | Kenwood Audio Players & Recorders
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
How do i hook my bose 901 equalizer into deno
The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
Beemer530
Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
I have qsc amplphier and a behringer eurorack and trying to hook up 532e Graphic EQ to it, how please? Not sure of what I can get away with far as cords go and where do i connect it?
you have to use a tape monitor record in and out connections ( RCA )
it will require two sets of rca jacks ( left and right) (eq in to record out on reciever tape monitor / eq out to reciever in record on tape monitor )
Dec 12, 2008 | Audio Players & Recorders
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
252 people viewed this question
Top Pyramid Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
