Hello, Thank You for using FixYa. I will be helping you today.Leave the power off remove the screws from under the panel and lift up to open the control panel. There are reset-able fuses in there check them by pressing the center red button if they are ok check the screen in front of the fan make sure its not blocked up it will cause this problem too.If all that is ok then the relay on the control fused closed and you would have to replace the control board with the relays on it.
Thank You and please rate my answer if it was helpful..
