Question about Ranger TR-696F SSB CB Radio
Adjust frequency alignment - Ranger TR-696F SSB CB Radio
Posted by mnhoundog on
Laron
    Novelist:
  • 146 Answers
Adjust L20 (AM) L21 (USB) L22(LSB)
Posted on Jul 03, 2011
How to adjust frequency on a uniden Grant XL
Take this to a shop that does it for a living, they have the correct equipment needed to align this rig
Mar 08, 2014 | Uniden GRANTLT 40-Channels Base CB Radio
Uniden grant cb radio
You can't You need a spectrum analyzer to set the frequency correctly. This is not something you can do by ear. When you go poking around inside with a screw driver, you can mess up the entire radio.One adjustment will affect other adjustments. That's why there are radio repair shops. Just take it to one.
Jan 23, 2014 | Radio Communications
Nakamichi BX 300 tape deck runs slow in play,belts and idler have been replaced
There is an adjustment in the motor that sets the speed however you need to have a frequency counter and speed alignment tape to adjust the speed correctly. There was also suppose to be oiling of the mechansm at the time the belts were put on.
Jan 05, 2013 | Audio Players & Recorders
Why is ch 6 om my cobra 29 is now ch7
It sounds like the radio needs to be re-aligned the TX frequency is out of adjustment.
Jan 01, 2012 | Cobra 29 LTD CB Radio
My pioneer ct-f7171 cassette deck needs a little speed adjustment, where is the pot located?
Usually on the back of the servo motor. You need a speed alignment tape and frequency counter or wow and flutter meter to do this adjustment correctly. Often times the speeds go up as the motor start to fail.
Aug 12, 2011 | Pioneer Audio Players & Recorders
Lsb its off frcwense but upr and am are fine
Adjust L21 WITH A NON METALIC ALIGNMENT TOOL THAT FITS INTO THE L21 SLUG to get it on frequency. IF YOU USE A METALIC TOOL, THE FREQUENCY WILL CHANGE WHEN YOU REMOVE THE TOOL. IF YOU TRY TO USE A TOOL THAT IS NOT THE CORRECT TOOL, YOU COULD DAMAGE THE SLUG AND END UP WITH A LARGER HEADACHE THAN YOU HAVE NOW..
Apr 08, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
29 LTD classic recieve is way off frequency. recieve sounds like bleed over from another channel. how do i adjust the receive frquency for a cobra 29 ltd classic?
un fortunatly to properly align this radio you need an audio VTVM, occiliscope and a dummy load.
but before you get crazy with trying to align your radio, is the delta tune right in the middle? if not thats why recieve is off.... as well you can adjust delta tune to compensate for off frequency.
Jan 04, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Only one channel is playing, i heard some music in stereo. Do heads need adjusting?
clean the head with alcohol.if the head surface is not smooth,it could be worn
.there is a small screw on the side of the head for changing the azimuth.
most front load tape decks have a small hole in the front of the door, when the outer part of the door is taken off.
the best way to align the heads with with a 10khz alignment tape and an oscilloscope.
the screw is adjusted for maximum high frequency performance.
a qualified shop should be able to do a complete service and align for around 50 dollars
Aug 18, 2009 | Audio Players & Recorders
SSB ALIGNMENT
You'll need to connect Frequency Counter to C252 & adjust:
USB Frequency: 10.6975Mhz adjust L126 in receive mode
LSB Frequency: 10.6925Mhz adjust L127 in receive mode
May 04, 2008 | Magnum DeltaForce CB Radio
Ranger TR-696F SSB CB Radio Logo
131 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
