SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
SOURCE: Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the dishwasher
(inside the junction box, behind the bottom kick panel), if this is
the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
SOURCE: I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel.
No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Testimonial: "Thank you so much for the quick and informative answer. It is greatly appreciated. "
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
