Question about Nuance Dragon NaturallySpeaking 11 Premium with Headset & FREE CheckIt Diagnostics Voice Recognition...
Trying to use the headset provided by Dragon 11 naturally speaking software. The headset has two jacks, a mic and a headphone one which I have set up via RealTek, although I cannot get playback on the headphones. When setting up Dragon 11 the only option it gave for audio is USB/Bluetooth microphones, but this headset is neither? It now can't pick up the audio source and it isn't giving any option for the headset. Not sure where to go next?
Posted by lmcinerney on
Steven Martin
    Dedicated:
    Visited the website for 20 consecutive days.
    Passionate:
    Visited the website for 10 consecutive days.
  • 19 Answers
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
Posted on Apr 18, 2018
1 Related Answer
Anonymous
  • 492 Answers
SOURCE: Dragon naturally speaking 11 is
It could very well be your microphone. The program needs to understand what you're saying and your microphone is crucial to that. If there's a lot of background noise or if the quality of your microphone is poor, you can check this by recording your voice and playing it back.
Posted on Jan 24, 2011
Plantronic headset has 2 plugs?
The easy way to find out is to plug it in one way while you're wearing the headset, and have the computer make some sound (play a video or something. If it's the correct way, you should hear the sound through the headphones. If not, you won't, so you'll need to plug it in the other way.
When you figure out which is which, make note of it so you'll remember next time.
1helpful
2answers
DRAGON NATURALLY SPEAKING, WHEN i CLICK ON ICON I GET ERROR "ACTXPRXY.DLL DID NOT REGISTER ITSELF" CAN I DOWNLOAD THE FILE ?
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it http://youtu.be/rNDBRYdDXqo ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website http://support.nuance.com/compatibility/ . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Dragon naturally speaking 11 is slower and less accurate than it was. Sound playback of dictated text is slow and distorted. Have redone mic checks and training but problem remains. Am thinking I should...
4helpful
2answers
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Stefan
1helpful
2answers
I need a softwar that can take notes through my headphone mic word/text
Alright, well you have many options to choose from.
If cost is an issue, you can try this free application:
http://www.e-speaking.com/free_voice_dictation_software.htm
However, if performance and quality are crucial, I would suggest going with some more esstemed products.
Products such as Nuance's Dragon Naturally Speaking:
http://www.nuance.com/naturallyspeaking/
Or a product from a company called VoiceBox:http://www.voicebox.com/
Also, try Downloads.com and see what you can find, if your not fully satisfied with the free link.
Let us know.
I have a Dell Inspiron 1525 without the webcam .. when I use my headphone jacks in the front of my laptop I'm able to hear but the they can't hear me through my headset microphone. They're only able to...
Be sure that your headphone mic plug jack is plugged in to the mic jack (right-most jack) and not the second headphone jack. If so, check your sound setting in Control Panel and make sure the mic is enabled and the volume slider for it is up.
Nuance Dragon NaturallySpeaking 11 Premium with Headset & FREE CheckIt Diagnostics Voice Recognition... Logo
Top Nuance Computers & Internet Experts
 Grubhead
Grubhead
Les Morrison
Les Morrison
ray gallant
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
