The air filter is a simple foam element, it can be removed by removing the filter cover, the cover is just underneath the fuel tank and secured with a push in plastic clip, the earlier version has a screw holding the filter cover and the filter is a flat rectangular element,
Check the clearance of the new coil to flywheel. It should be about .010" (aout the thickness of a standard business card). Also check that you didn't jam the start on the flywheel dogs.
This is classic fuel blockage, start by changing the fuel filter in the fuel tank, if no better check fuel hose has not collapsed or become trapped, if no better remove the carb, under the pump cover ( alluminium cover held with a single screw ) under the diaphram is an internal filter, clean or replace.
I found the manual for this model weed eater, according to the manual the mixture... and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be mixed at a Ratio of 40:1 ...." and I quote once more from the manual "Helpful Tip. To obtain correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps, If you like I can send the manual via email if you need it.
