HEWLETT-PACKARD Hewlett Packard HP 15.6" Pavilion G62-355DX Athlon II Entertainment 3GB Laptop 320GB Notebook PC (XH068UAABA) Logo
Posted on Mar 13, 2017
HP G62-355DX laptop I bought in May keeps shutting down. There is not set length of time or specific program when it happens. It seems like the computer is still on but I just have a blackish/gray screen and I cannot do anything but hold the power button, shut it down and power it back only for it to happen once again. I update windows, HP software, and Norton, ran Norton scan, and the problem persists. Any thoughts? SPECS: Operating System Windows 7 Home Premium 64-bit CPU Type AMD Athlon II Dual-Core P340 2.2GHz Memory Size 3GB DDR3 Hard Disk 320GB Optical Drive DVD Super Multi Graphics Card ATI Radeon HD 4250 Video Memory Shared memory Communication LAN and WLAN Tech VISION Technology CPU Type AMD Athlon II Dual-Core CPU Speed P340(2.20GHz) CPU L2 Cache 1MB
cyfred
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Mar 13, 2017
cyfred
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
4213
Points
10
Could it be getting too hot somehow? Maybe the fan intake air vents are blocked.
2 Related Answers
A
Anonymous
  • Posted on Nov 04, 2010
SOURCE: i can not install windows
You need to add the SATA hard drive controller to the XP installation CD using the program NLite.
Follow this guide:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Anonymous
  • 10 Answers
  • Posted on Aug 25, 2011
SOURCE: Describe your Hewlett Packard HP
Hello Sir/Madam,
If you can properly state the problem with your system then a solution will be provided for you, thats the reason why this website exist.
Thankyou.
tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 • Computers & Internet
Why does it keep shutting down
what are you doing when it shuts down? i'm having a similar problem with my HP. if i have the laptop on a hard, flat surface like a table, it works perfectly, but when i move the laptop to my lap, that's when it shuts down. it seemed to happen every time i touched the battery area. found out that it's a bad motherboard and i have to send it in to HP to be repaired.
Computer continually reseting
I will need to know what operating system you are using and does all the programs reset itself?
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and...
information. hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
2helpful
2answers
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • 0helpful
    My h1000e takes long to shut down?what could be the cause of this and how do i solve this problem?
    Pepper, It seems that you installed something that is causing this problem. What happens is that when you shut Windows down, it has to close all programs running, whether in the foreground or in the background. Now, when all programs are shutting down properly then there is no problem. But when some one decides to resists the shutting down then Windows takes longer to abide by your instructions. You have to find out this/these program/s that you installed recently. Uninstall them if you can do without them. Alternatively close them manually before shutting down. What programs are these? That you alone can find out. Another reason. Does Windows seem to take longer while "Saving Your Settings"? If that happens, then there may be something wrong with Windows. Be prepared to reinstall Windows. Do not get alarmed, but just keep it at the back of your mind. Keep taking backups of your data regularly to be on the safe side.
    2helpful
    HP Pavilion dv1000 laptop turn off suddenly and cpu fan is working ok. after goes off is hard turn on again, not is battery neither ac adapter but i have seen that many people has the same kind of problem,...
    If this happens while you are using it, then that's one thing.
    We will get to that later.
    If it happens while the unit is just sitting there, then that's another thing.
    You probably have an energy savings setting problem that you can easily resolve simply by going into the My Computer equivalent and reconfiguring your length of time prior to shutdown of either the display and/or the hard drive.
    Find the "DISPLAY" Icon and click on it and you will find a variety of energy saving routines which you can set to the amount of time that the unit will stay on, even though not in use, after which it will shut down to save energy and wear and tear on your components.
    Now, as promised, if this occurs while your unit is in use and just shuts down while you are typing, then your unit requires service by a professional as there apparently is some kind of shortage which with further use could damage your unit.
    I hope this helps, but if you have further questions, feel free to ask.
    My hp notebook pc keeps on shutting down every 10 minutes or so
    Check out HP's web site regarding an Enhanced warranty program for specific laptops. My DV6113us had a problem with it restarting and it was one of the model numbers covered. Bad Motherboard....
    Top HEWLETT-PACKARD Computers & Internet Experts
    Paul Bade
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
