Question about Nintendo Video Game Consoles & Games
Setting up wii for netflix - Nintendo Video Game Consoles & Games
Posted by stephanie14218 on
sherwin alvarez
    Scholar:
  • 55 Answers
Netflix Instant is available for streaming on your Wii gaming console by early spring 2010. If you have a Netflix subscription you can watch movies and episodes easily on your TV through your Wii console. This article will detail the important things you will need to make sure that you can watch Netflix from the Wii.
Difficulty:Easy Instructions Things You'll Need
  • Netflix subscription
  • Nintendo Wii gaming console
  • Broadband internet
    • 1 Check you Netflix subscription. The minimum subscription plan to watch Netflix instantly is the unlimited 1 DVD at a time plan or otherwise the $8.99 plan. This plan allows to watch movies instantly with unlimited monthly hours.
    • 2 Check internet bandwidth on your broadband connection. According to Netflix the minimum bandwidth requirement is 1.5Mbps. Netflix recommends for watching movies instantly a 3.0Mbps connection. Check with your internet service provider to confirm that these download speeds.
    • 3 A wired connection to your Wii console. An ethernet connection to your Wii console would be preferable. Unfortunately the Wii console does not have an ethernet port but a USB port. A USB LAN Adapter can be found at most computer supply merchants or online from Wii or Amazon.com. The ethernet connection is an ethernet wire from your home LAN router connected to your USB LAN adapter. The USB LAN adapter is then connected to the USB port on the Wii console. This connection will be how Netflix provides the movie streaming feed to the Wii.
    • 4 Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Read more: How to Setup Netflix for Wii ' eHow.com http://www.ehow.com/how_5893624_setup-netflix-wii.html#ixzz1OybxaAO2
if this help you please rate me sir thank you so much...
Posted on Jun 11, 2011
How do I set up netflix via wii?
I asume you setup your WiFi connection, so next you have to:
1)Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii.
2)Select "Free 0 Wii Points.
3)Select either the "Wii System Memory" or an "SD Card" as the download location( In case you have a SD card plugged in).
4)Select "OK," then "Yes" to download the channel.
5)Once Netflix Instant Streaming for Wii has finished downloading, it will appear on the Wii menu.
6)Once installed select Netflix from the Wii men?.
7)When asked if you are already a Netflix member, select "Yes" to reach the Member Sign In screen. If you are not already a member, select "No" and fill out the required fields on the screen to begin a free one month trial.
On the Member Sign In screen, click "E-mail."
8)Using the onscreen keyboard, enter the e-mail address that you have associated to your Netflix account, then click "Enter." (This is the same e-mail address you would use to sign into Netflix.com.)
9)Select the "Password" area, and use the Wii Remote to enter your Netflix account password. Select "Enter" when finished.
10)When your e-mail and password have been entered, select the "Continue" button.
11)Once you have successfully signed in, the Wii will automatically display your Instant Queue.
Nov 01, 2014 | Nintendo Wii Console
Where's the activation code on nintendo wii?
How to get Netflix to work on a Wii
1.) turn on your wii
2.) press "A" (or any button to get to the wii menu)
3.) on the Wii menu, go to the bottom-left of the screen
4.) click "A" on the word "Wii" (when you highlight it, it should say "Wii Options")
5.) then click on "Wii Settings"
6.) on the contoller, hit the "+" button then click on "internet"
7.) then click on "connection settings"
8.) click on any connection setting (i just use the the one that says "connection 1")
9.) if you want to connect through a wireless connection, click on wireless connection (this will search for WiFi around you.)
10.) then go to "search for an Access Point"
it should find some access points, if it doesn't, then you'll need to buy a Nintendo WiFi thing (i'm sorry, i forgot the correct name for it)
11.) click "OK"
12.) click on an access point with a lock that's unlocked, or click on one with a yellow lock and put a password. if you see a red lock, you cannot connect to that access point.
13.) it will ask you if you want to save the settings. click "OK"
14.) then click "OK" again, to do a connection test (this could take about 30 seconds)
15.) UPDATE THE WII
16.) after that go back to the Wii menu by clicking "Back" until you reach the Wii menu
17.) then click on the wii shop channel.
18.) then click on start shopping
19.) then click on channels
20.) then click on netflix
21.) wait for it to download
22.) then go back to the wii menu
23.) then load up the netflix channel
24.) they're going to give you a password, go on a computer and (if you have a netflix account) go to www.netflix.com/activate or http://www.netflix.com/NRD/Wii?mkwid=s0BEmMX1Q&mqso=80025460
25.) then loggin and type in the code from the wii into your accound
...Now you can watch Tv or movies on your Nintendo Wii
Aug 19, 2012 | Nintendo Wii Console
Downloading netflix
11.) click "OK"
15.) UPDATE THE WII
Aug 18, 2012 | Nintendo Wii Console
I dont know how to download netflix on my wii
Connect your Wii console to the Internet A broadband Internet connection and access point are Follow the steps below to get connected.From the Wii main menu, use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet. Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks,The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.Once the Wii finishes downloading any updates, you will return to the main Wii menu screen. You will now need to download Netflix Instant Streaming for Wii from the Wii Shop Channel, then connect your Wii console to your Netflix account. Please see the step-by-step information below to finish the process and start watching Netflix content on your Wii.Download Netflix Instant Streaming for Wii from the Wii Shop Channel Now that your Wii console is connected to the Internet, you can download the Netflix Instant Streaming for Wii from the Wii Shop Channel. Once it's downloaded, you'll use it to stream movies and TV episodes with your Wii.
1 Select the Wii Shop Channel on the Wii Menu.
  1. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement.
  2. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
    • If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right.
    • If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
  3. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  4. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account. Continue reading for more information.Connect your Wii console to your Netflix account Before you can watch TV episodes and movies streaming from Netflix, you will need to connect your Wii console to your Netflix account.On your WiiIf you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  5. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to http://www.netflix.com/wii. (You will need to log into your Netflix account if you're not already logged in.)
  6. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  7. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  8. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu
Aug 17, 2011 | Nintendo Wii Console
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
  1. On your Wii
  2. On your home computer
  3. Still on your home computer
  4. Back to your Wii
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
Jul 11, 2011 | Computers & Internet
How do i get the internet connection on the wii to get netflix
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
Once you have set up your wifi connection you can download the netflix channel from the wii shop channel for free. Then you can follow the on screen instruction when you launch the netflix channel to watch netflix on your wii.
Apr 30, 2011 | Nintendo Wii Console
How do I set up for nesflix
Netflix on your wii is a great feature. You set up netflix by going to the wii store channel on the wii console and downloading the netflix channel to your wii. You have to have internet set up on your wii first. Then after you have the Netflix channel downloaded you can go to it and set up your netflix account through that channel.
Apr 27, 2011 | Nintendo Wii Console
How to watch movie from netflix on the will
First download Netflix from the Wii Shop Channel, then go into your Netflix account settings and click Activate a Netflix ready device. Enter the code you see on the Netflix Channel on your Wii into the box on the website.
Apr 19, 2011 | Nintendo Wii Console
Video Game Consoles & Games Logo
2,103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
