Question about Whirlpool Washing Machines
You didn't state the brand or model of the washer so i can not answer your question full. If you are talking about the standard top load washer, i can say that most all washers do not have a removable back. older top loads usually just the front panel comes off. some newer ones the front and sides come off as a unit. sorry, this is the best i can do with the info you gave. you can re-post with more info on the washer and what you are wanting to do. Thanks
Posted on Jun 11, 2011
You didn't put the model number but most washers today you don't take off the back.Remove the top panel where the timer and controls are. Then you will see two big brass clips remove them, then the entire cabinet comes forward and off. Hope this helped.
Hello, Thank You for using FixYa. I will be helping you today.If its a front loader just remove all the 1/4 inch screws from the back cover. If its a top load remove the control panel back corner screws flip up control remove two clips unplug lid switch and remove the whole cabinet.The back does not come off the top load whirlpool.
Thank You and please rate my answer if it was helpful..
