Question about Garmin GPS
I have nuvi 250 which needs the UK update. It has a memory card slot on the side. By using the card will I lose the European maps or does it just overide the UK maps
Posted by junelol8 on
Joe Bannon
  • 1,514 Answers
If it already has the European map then updating the European map will also update the UK map since the UK is part of the European map. You can get more details of how to update your map at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Posted on Jun 11, 2011
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
Jul 27, 2014 | Garmin nuvi 1490T GPS Receiver
My Garmin Nuvi 250, when plugged into cigarette lighter, switched from a working screen to a non functional screen that has picture that looks like a computer tower with cord or a usb cord or something...
New , later maps for the Garmin take up more space that what unit has in available memory - so you have to get an sd memory card to put in the slot when you do the update.
Jun 12, 2017 | Garmin nuvi 250W GPS Receiver
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Can i download maps of germany,switzerland and france onto my Garmin Nuvi 255 now that it already has australia and nz on it
You can, but...
You'll need to load the mapping onto a removable memory card, as your device's memory isn't large enough. Adding a memory card with additional maps really slows the machine down, painfully so. Buying the European mapping pack isn't cheap: you can buy a brand new satnav with full European (including UK and Eire) mapping preinstalled for about the same price. Click here for a current example, but there are cheaper ones if you abandon Garmin in favour of Medion or other brands.
It works out even cheaper if you sell the old satnav to fund the purchase of the new one. When you need the Oz/NZ mapping again you can do the same thing again as by then your original unit will probably have out of date maps anyway.
Please take a moment to rate my answer.
Jul 22, 2010 | Garmin nuvi 255W GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Feb 27, 2009 | Garmin Nuvi 660 GPS Receiver
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top Garmin GPS Experts
Sheldon Dedek
Tom Chichester
Bill Boyd
Are you a Garmin GPS Expert? Answer questions, earn points and help others
