If you can locate the vertical IC (located on a heatsink) you will find this IC needs resoldering. This is a common problem with RCA TVs. The vertical IC is of a TDA series number. It will have seven pins. Examine very close and you will see cracks or rings around each pin. Resolder these, do not use excess solder or you will short the pins together. Inspect any and all solder grounds in this area, resolder as necessary. Thanks for asking and show all hands of support!
