Question about Danby DDR607EE Dehumidifier
My Daby dehumidifier will sometimes have coade P1 show up on LED readout and also go to high fan. I have it in basement and set at 50% and low fan. What is the problem? I have to disconnect and reconnect and then will work properly. Thanks you. June
Posted by parkers2 on
fixer521
    New Friend:
  • 49 Answers
Don't know what the P1 code means, but maybe your demand of 50% and low fan is not able to be achieved so the unit will increase the CFMs (high speed on fan) to try and reach the 50% humidity level you are asking it to do within a certain time period.
Posted on Jun 11, 2011
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
Fan works but compressor does not kick in, therefore does not collect water. temperature and humidity in basement : same as before
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Ihave the dehumidifier turned on in my basement...fan runs....displays show the humidity, and temperature...but the tray does not fill up with water at all. Is there a specific setting for the humidity..I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 13, 2010 | Fedders A7DH45B2A Dehumidifier
Can you tell me about the "P" readouts?
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 02, 2010 | Danby DDR601 Dehumidifier
Iced over
I thnk you are expecting too much from your machine. DO NOT RUN IT WHEN IT IS FROZEN!
This is what I would do. Slow down the process. You shuld be agle to select the % humidity you seek. Set it high, say 90. Get another fan in your basement working to sirculate the air. When your machine has achieved this goal without excessive running and freezing, go to 85% or 80%. It may help if you direct a small fan at the coil that freezes.
Are you certain your machine drains properly? Hose to a sump pump? Is the sump pumping properly?
And lastly, you may want to add a second machine. I operate two in my basement and they keep it 50% in the summer. My basement is about 4000 cubic feet.
I hope this helps you
a
Sep 27, 2009 | Dehumidifiers
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
Cycles every 3 minutes
It may be in a basement that is to cool. Unless this is a special low temp dehumid it needs to be in the upper 60's to work correctly. Also a 50 pint is for a pretty good size area, if it is in a small area or if the temp is to cool in the basement it is in it will freeze up and cycle off. 3 min is awfull quick though. It may be low on freon also. Just a couple things to think about.
Jun 20, 2009 | Whirlpool AD50USS Dehumidifier
Danby DDR607EE Dehumidifier Logo
536 people viewed this question
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
Moderator Canada
Moderator Canada
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
