Question about Dane-Elec DaneElec 2GB USB Drive Red Hard Drive
I just bought the red 2gb usb portable memory and my computer wont recognize it. i'm on a laptop with windows vista ultimate do i need to format the stick? how?
Posted by snoland88 on
Brian Sullivan
  • Dane-Elec Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on Jun 11, 2011
How to solve the problem " please insert the disk into drive" of memory card
ok how did format get done? if not on computer then formatting needs to be done with card in computer and do a thorough format NOT quick format
May 26, 2012 | SanDisk 2GB microSD Memory Card
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I just bought 2gb SanDisk Memory Card, a few days ago it requires to be formetted and I dont know why. When I intend it to format at my PC it just says "Windows can't format E:/". What should...
try using linux
then also try using your phone or whatever the disk was to be used if not then g to control panel and look for the administrative tool click it, go to computer management and try format it from there. If all this can't work then, return the product to the dealer
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
Pny 2gb not recognized by windows vista
Try connecting it some other computers.
If it does not work at all, spend $8 to replace it.
If it does work, then it's either the "hardware" on your computer, or the Vista "software" (wrong/missing USB device-drivers).
Apr 20, 2011 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Have Sony 1GB memory stick "magic gate" that wont open on my laptop vista
ok
try
these steps:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 17, 2010 | Lexar JumpDrive Classic Portable USB Data...
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
MicroSD wont work in MP3 player
mp3 player wont recognize videos....jus mp4 will do it if the video is in mp4 format
Aug 22, 2008 | SanDisk 2GB microSD Memory Card
USB Cruzer
you just need new software for that. check sandisk for updates for your usbdrive. many thanks. :)
fixya!
Jan 29, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Kingston valueram 512mb
How do you mean nothing is showing up?
The fact you can get into BIOS usually means that something is right.
This board can go upto 2GB RAM
look at the kingston configurator page for info and compare it against the memory you bought (exact part numbers are a must). With Windows VIsta Ultimate you should be using 1gb Sticks not 512.
Oct 25, 2007 | ASUS P5RD1-VM Motherboard
Dane-Elec DaneElec 2GB USB Drive Red Hard Drive Logo
74 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
