I have the same model and also had a problem with the door not opening. The cable from the door latch goes to a clutch that prevents the door from opening while the motor is spinning. In my case, adjusting the clutch fixed the problem (adjust it while the machine is running). The problem could also be where the cable attaches to the door interlock, in the interlock device, or in the cable itself (bent, broken...). The interlock also prevents the door from opening when there is water in the drum.
Good luck.
Good luck
