Question about Xitel Pro HiFi-Link External Sound System
I have an Xitel Hi-Fi link, USB type. For some reason it stopped working on my Dell Windows 7 machine. When I check the device manager is shows it with a yellow icon and says it's not working. Uninstalling and re-installing doesn't help. wWhen I try to update drivers, it can't find any. Help please?
Posted by tal1412 on
Josh
    Sergeant:
  • 308 Answers
The product details say that is a plug and play device, this means it shouldn't need a driver, how ever with it being used with windows 7, I don't know if that makes the difference. Shouldn't, but never no, I also had no luck finding drivers. I would uninstall the drivers associated with it and reboot your computer with this hooked up and see what happens.
Posted on Jun 10, 2011
Dell inspiron 2330; I cannot use keyboard for anything but the mouse is still working, How can it be fixed?
check the device manager under "Human Interface Devices" and see if the keyboard has an exclamation mark on yellow ground. If so it means you need a driver.
Mar 10, 2015 | Dell Computers & Internet
All (4) of the USB ports on my Dell Latitude D630 seem to have stopped working, particularly when using readers to access Micro SD. Any ideas anyone? Or is it a case of "off to the menders"?
Hi
If thay have all stopped this would point to a hardware fault but It may be worth unistalling the drivers for the USB and also checking the BIOS to make sure you have not accidently disabled them in there
Cliff Cook
MCP
Aug 03, 2014 | Dell Latitude D630 PC Notebook
Smartdisk Firelite model usbflb80 is not recognized on my laptop
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Or even get a usb 3 lead. USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Jan 24, 2013 | Computers & Internet
My buffalo drivestation external harddrive don't power up?
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 02, 2013 | Buffalo Technology Buffalo 1TB Drive USB...
It spins but is not recognized by computers
What type of hard drive ?
b>
Dec 20, 2012 | Computers & Internet
Driver HX-DU010EC
Windows 7
Hope this helps
Nov 22, 2012 | Samsung G3 Station 1TB USB 2.0 Black...
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Jan 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My usb ports stop working my mouse shows there is power but it is not working wat can i do to fix it i have a dell precision m70. i dont know anything about computers show me step by steb wat to do
check in device manager next to usb see if theres any yellow question marks next to anything related to usb.expand it down to see all
start-[type in search box] device manager] click on it when it appears.Device manager will open.expand by clicking on the+ next to devices.
Jan 03, 2010 | Dell Precision Workstation 670 PC Desktop
Xitel Pro HiFi-Link External Sound System Logo
837 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Bill Boyd
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
