SOURCE: dvd disk cannot be used to write
You should ring Sanyo helpdesk direct for fault like this as you shouldnt be having problem of this nature also would be good idea to go back to where you bought it to see if they have heard of problem,.
SOURCE: Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
SOURCE: i cannot record on my recorder i have memorex
Does the player portion work OK? BTW, try another manufacturer's blank DVD. Most folks I know have had problems with Memorex media.
Are these New DVDs or ones you've used before?
