SOURCE: Can I save a WAV file to MP3 format
There is a free program called Media Monkey - it will convert WAV format to Mp3 (actually, it will convert any non-protected music file type - it's very dynamic). It may take a while to figure out how to do the first one, but it will get easier after that.
First, you have to plug the Thomson in to your computer, double-click "My Computer," and then double-click the icon of the Thomson. There should be a folder called "Voice or "REC". If it doesn't show up, select in the window: Tools --> Folder Options --> View --> select Show Hidden Files and folders. Now the right folder should show up. Then, drag the WAV recording to your desktop (or your "My Music" fodler - whichever works best for you), and the computer should make a copy of the WAV recording onto your computer.
Now open up Media Monkey and it should, after several minutes find all music files on your computer, including the WAV recording. Then right-click the WAV recording, and it should have an option to covnert the file type - convert to mp3, and you're done.
-Tha Mp3 Doctor
SOURCE: thomson lyra will not record 'audio-Hard Drive is
copy your file and format the unit and try again to see if it works. I hope this solution has been helpful.
SOURCE: I am trying to get
The Thomson XC0382 voice recorder appears to be the same as the RCA VR5440R, and the manual is available from
http://www.rcaaudiovideo.com/audio/voicerecorders/?sku=VR5330R
First of all, check the remote control handset for its infrared emission. If found OK, try a reset to this set, and check further. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked above.
