Good Day Fschiavelli4!
There are few reasons why PC will not recognize a printer.
First, the driver installer for the printer was not installed in your PC.
If somehow, already installed, then procedure may be wrong. I recommend you go over again with the installation set up. But this time make sure when you install the driver the printer should not be connected to the PC. Once, during the installation, when prompt to connect the printer via usb, that's the only time when you will connect the printer.
Second to consider is the usb slot in your PC. It is always advised that when you connect the usb cable on the usb slot of your computer and the system did not recognize it, you should look for another usb slot and try it there.
The last to consider is the faulty usb cable. It might be worth to try different cable just to verify if your current usb cable is not faulty.
Testimonial: "Thank you...it turned out that I needed to do a complete reinstall of the printer. "
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
