Question about Behringer EURORACK UB2442FX PRO Mixer
I'm looking for a solution how can i connect my
Posted by nestor_libed on
Vito Vacirca Jr.
  • 140 Answers
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Posted on Jun 10, 2011
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
How do you set up for a simple pa system?
It Depends how many Channels you are wanting for a basic 2 deck set up using Cdj's you would want 4 channel 2 per deck 1 master out and 1 booth so you can hear it through your head phones but if you were doing Karaoke you would want 6 channels for 2 microphones all going 2 the master out. but it changes again if us software and controller because most software has an internal and external mix mode. Here is a video that might help
Sep 02, 2014 | Behringer EURORACK UB2442FX PRO Mixer
How to link 2 mixers
VIa, XLR, TRS, 1/4 Jack, phono,,
Jul 19, 2014 | Behringer EURORACK UB2442FX PRO Mixer
Effects won't work stuck on d2
Hi, did you find a solution for this problem? I have it too.
Nov 16, 2013 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer EURORACK UB2442FX PRO Mixer Logo
411 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
