To remove and clean the printhead on your Canon IP1300 printer, follow these steps:
Turn off the printer and unplug it from the power outlet.
Open the printer cover and raise the printhead lock lever.
Lift the printhead out of the printer.
Moisten a cotton swab with warm water and gently clean the printhead nozzles. Be sure not to touch the gold-colored electrical contacts.
If the printhead nozzles are heavily clogged, you may need to soak the printhead in a solution of warm water and a mild cleaning agent for a few hours. Be sure to follow the manufacturer's instructions for the cleaning solution.
After cleaning the printhead, shake it gently to remove any excess water, and then let it dry for a few hours.
Once the printhead is dry, replace it in the printer and lower the printhead lock lever.
Close the printer cover and plug the printer back in.
Turn the printer on and perform a printhead alignment to ensure that the printhead is properly aligned.
If you are unable to clean the printhead or if the problem persists after cleaning, it may be necessary to replace the printhead. A new printhead can be purchased from the manufacturer or an authorized dealer.
Step one: Clean the contacts on the printheadCAUTION:
Electrical contacts contain sensitive electronic components that damage easily.
Gather the following materials:
Dry, soft, lint-free cleaning cloths (coffee filters and eyeglass-cleaning cloths work well)
Paper towels or clean sheets of paper
Lift the product lid. The top cover rests in an open position.
Figure 1: Lift the lid
Press and hold the OK button for five seconds. The carriage moves to the left side of the product.
Unplug the power cord from the rear of the product.
Figure 2: Unplug the power cord from the rear of the product
Inside the product, lift the blue printhead latch.
Figure 3: Lift the printhead latch
Lift the handle of the printhead, and then pull the printhead out of its slot.
Hold the printhead by its sides, and wipe the electrical contacts on the printhead with the cloth. Do not touch the nozzles.
CAUTION:
Do not use water or other cleaning materials.Do not touch the nozzles on the printhead.
Figure 4: Clean the printhead contacts, but do not touch the nozzles1 - Nozzles - Do not clean2 - Contacts - Clean
Set the printhead on a sheet of paper or paper towel with the nozzles facing up.
If necessary, repeat these steps to print the other printhead.
Step two: Clean the contacts inside the All-in-One
With a fresh cloth, wipe the electrical contacts inside the carriage.
Figure 5: Wipe the contacts inside the carriage
Plug in the power cord to the rear of the product.
Press the Power button ( ) to turn on the product, if it does not turn on automatically. The message 'Printhead missing ' displays on the control panel.
Hold the printhead by its sides with the nozzles toward the product, and then insert the printhead into its color-coded slot.
Insert the Black/Yellow printhead into the slot on the left.
Insert the Magenta/Cyan printhead into the slot on the right.
Figure 6: Insert the printhead into its slot
Repeat these steps to insert the other printhead into its color-coded slot.
Pull the blue printhead latch all the way forward, and then press down to fully engage the latch. You might have to apply some pressure to engage the latch.
Figure 7: Lower the printhead latch
Close the product lid.
Figure 8: Close the product lid
Wait for the product to initialize the printheads and print an alignment page. This process takes about 20 seconds.
The Kodak printhead is known to dry out. You can call kodak customer
service and complain your printhead is failling explain you have run
the printhead cleaning many times waisting your ink. They should ship
you a new printhead.
or if you dont want to wait on the phone....
I
have found lysol hand wipes to work wonders on the kodak printhead. I
have an ESP 5 and I have wiped the printhead with a lysol hand wipes
many times and it works like new. Here is a link to the product. http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove
the printhead from the printer. put the tanks back into the printhead.
Be very carefull not to drop the printhead and do not put the printhead
on a table with the nozzle plate down (where the ink comes out). take
the hand wipe fold it a couple times. Gently wipe the printhead nozzel
plate in the direction of the lines on the nozzle plate do not do a
circular motion or wipe against the grain. you may not even have to use
a wiping motion. you can just place the wipe on the nozzles and let the
printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
Follow these steps to replace the
printheads in your printer.
Press the Power
button (
) to turn on the
printer.
Open the top cover.
Press and hold the
Resume
button (
) until the carriage moves to the left.
CAUTION:
Be careful not
to proceed until the carriage is on the left side of the printer. If
the carriage does not move to the left automatically, turn the printer
off and back on and then try holding down the
Resume
button (
) again. The printhead can be damaged if the carriage is not all the
way to the left for installation.
Lift the printhead latch.
Figure 3:
Lifting the printhead latch
Lift the handle of a printhead and use it to
Figure 4: Removing the old printhead
Shake the new printhead at least six times
while the printhead is still in its packaging.
Figure 5: Shaking the
new printhead
Remove the new printhead from its package, and
then remove its orange
protective caps.
Figure 6: Removing the protective caps
CAUTION:
Do not shake the
printheads after removing the orange protective caps.
Insert the printhead into its color-coded slot
(the label on the printhead must match the label on the printhead
latch). Press down firmly on the printhead until it snaps into place.
Figure
7: Inserting the new printhead
Pull the printhead latch all the way forward,
and then press down until the latch engages.
Figure 8: Closing the
printhead latch
Close the cover.
Figure 9: Closing the cover
The printer should align the printheads
automatically in a few minutes, printing an alignment page. If it does
not, go to the next section to align manually.
Align the printheadsIf
you installed the HP software, use the instructions in the left column
below. If you installed a Plug and Play driver or other driver, use the
instructions in the right column.
First you need to turn On the printer and open the printer access door
where you can see the Ink. Now wait for the Printhead to stop into the
middle then remove the ink cartridges both ink and black., Now to rmove
the Old printhead you need to press a Tab which is hidden on the
printhead., heres the step to remove the printhead which for me the
hardest part
-Point your index finger on the white sticker that
attached on the printhead or the bullseye sticker(If theres no white
sticker on the print head just put your index finger on the middle of
the printhead)
-Now your index finger is on the middle of the
white sticker right? Move your index finger upward unti you feel a
latch that you can press., Just press and full then your printhead wil
be removed
-Now Your ready to insert your new printhead -To
insert new printhead just put the printhead on the carriage of the
printer and gently press the white sticker of your new printhead make
sure that you will hear a clicking sounds then put your cartridges back
-Theres
some instances that the printhead will not stay on the middle., it
keeps on staying on the right or on the leftside for you to solve that
heres the step
-Turn on the printer open printer access door and
wait for the printhead move into the center and if the printhead its on
the center immediately unplug the power cable so the printhead will not
move.
First you need to turn On the printer and open the printer access door where you can see the Ink. Now wait for the Printhead to stop into the middle then remove the ink cartridges both ink and black., Now to rmove the Old printhead you need to press a Tab which is hidden on the printhead., heres the step to remove the printhead which for me the hardest part
-Point your index finger on the white sticker that attached on the printhead or the bullseye sticker(If theres no white sticker on the print head just put your index finger on the middle of the printhead)
-Now your index finger is on the middle of the white sticker right? Move your index finger upward unti you feel a latch that you can press., Just press and full then your printhead wil be removed
-Now Your ready to insert your new printhead -To insert new printhead just put the printhead on the carriage of the printer and gently press the white sticker of your new printhead make sure that you will hear a clicking sounds then put your cartridges back
-Theres some instances that the printhead will not stay on the middle., it keeps on staying on the right or on the leftside for you to solve that heres the step
-Turn on the printer open printer access door and wait for the printhead move into the center and if the printhead its on the center immediately unplug the power cable so the printhead will not move.
Hope this helps you.
This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced.
Step 1 - Remove all printheads
CAUTION:
Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children.
Figure 1: HP 14 printhead1 - Handle2 - Tower
Make sure the unit is plugged in and the power is turned on.
Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
Wait two or three seconds, then unplug the power cord.
Open the printhead latch. See the illustration below.
Figure 2: Open the printhead latch
Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below.
Figure 3: Remove the printhead
Step 2 - Reset the internal error state
NOTE:
This step must be performed before the printheads are re-installed.
Close the printhead chute.
Close the access door.
Plug the power cord back in.
Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now .
NOTE:
The carriage may make a grinding noise when you turn the power on. This noise is normal.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry.
Step 3 - Insert the printheads
Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead
Step 4 - Close and check the printer
Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below.
Figure 5: Loops catch hooks
Snap the latch into place.
Plug in the power cord.
Close the print carriage access door.
Turn on the power.
If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
