Question about Home
I have an American Valve M72AS Frost Proof Sillcock that is leaking around the stem when turned on. I replaced the packing under the handle with no fix. Is there another packing/seal deeper inside? How do I get to it? The joint is behind drywall and not visible. The manufacturer sent me instructions on how to install a new valve.
  • peasterday40
    peasterday40 Jul 04, 2012
    hello..Ive got the same problem...I think.... my valve leaks at a hole in the stem of the valve when I turn it on...some water still comes out the spout ..but most of it comes out the stem...I did notice that when I turned the faucet on...leaf debris came out...im suspecting ...critters have tried to nest in the spigot...so...I suggest that you remove the stem as I am going to..(after turning off the water)...once youve got it out...if you have someone to help..hold a mesh cooking strainer over the neck of the body of the faucet...have them turn on the water...see what debris/parts come out..Im going to try this...let it flush...then have them turn the water off again...inspect the strainer for parts...if none are found...inspect the stem for damage..Im hoping that this will solve the problem for both of us...Im suspecting that there is damage to the internal parts of the stem...due to overtightening...thanks
    phillip
scotty560
    New Friend:
  • 8 Answers
AMERICAN VALVE 1/2-in Dual Pattern Brass Sillcock Valve M72AS...
Do NOT purchase this product... Mine lasted about four years for me before the internal stem/rod cracked. This caused a constant leak when it was turned on. Doing research for parts... I've noticed a lot of reviews on the internet about this same problem as to it leaking through the handle. I thought it was a gasket problem but after analyzing it, it turned out to be the "Integral Vacuum Breaker" system malfunctioning after a few years of use. The tip of the stem is a moveable item loaded on a spring and if it gets stuck closed, the water in the stem/rod does not drain out causing water to stay in the center stem/rod and of course freezing during the winter. When Spring comes and you turn on the system, that's when it leaks in and around the handle.
Another important note: I could NOT find replacement parts i.e. center stem/rod therefore causing me to buy another new Freeze-Proof Sillcock. It doesn't stop here yet....The newer ones are mostly made of aluminum and the center stem/rod is all aluminum...NOT copper!!! This part being all aluminum which I believe will be a major problem to come!!! As you know aluminum creates lots of oxidation with layers of white aluminum powder. This will now be going through your hoses that might feed your garden/food, your pets water bowls outside and your pools!! This is not good. They need to keep this stuff copper or CPVC but NOT ALUMINUM.Look up "Aluminum poisoning"
I have pictures of this (center stem/rod) and how I fixed the old copper center stem/rod for a back up when my aluminum one I just bought from Lowes fails in a few years. I tested it and it works (my old copper stem/rod)!!! I fixed mine by removing the spring in the tip and putting the tip back in the stem and filling the center of the stem/rod with Liquid Nails adhesive. If I was to do it again, I would use a Rubber Silicon via a tube gun.
My suggestion is to go to the old type of Frost-Free Sillcock "BRASS" NOT ALUMINIUM and doesn't have a hollow center stem/rod for water to freeze in and also doesn't have the anti-Siphon design. It might be a neat design but when the parts start to oxidize/rust etc. it then will stick and keep the water from being aloud to leave the stem/rod therefore causing a crack and WILL leak when opened during the Spring.
Posted on Sep 05, 2014
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: my water supply valve for
The valve may have junk in it preventing it from shutting all the way off. Gently tap the valve a few times with a hammer and see if this clears it. IF not go to this site for other ideas http://www.ehow.com/video_117350_stop-toilet-running.html
J.
Posted on Aug 09, 2010
woobie dog
woobie dog
  • 1273 Answers
SOURCE: diverter valve does turn to redirect the water
Hello. W/D here....
I'll have to be general in this info as I don't know your specific valve, but I have worked on many diverter valves.
Either the packing gland on your valve is too tight, or you have a damaged diverter valve.
1. Make sure water won't come out in the tub or shower when your water is turned off; that is, that your water valves don't leak. If they do, you'll have to shut off the water.
2. Gain access to the valve body/diverter valve: Remove the plastic cap on the knob, remove the screw then remove the knob. The metal tube will unscrew from the valve body.
3. It gets a bit tricky here, so bear with me... Looking down the valve stem, there are two nuts surrounding the valve stem. The one closest to you is the packing gland nut. The inner one is the valve cartridge nut. The tricky part is that the nuts are difficult to get at. Turning (loosening) on the outer nut will make the valve easier to operate, and more likely to leak. A general rule for packing glands is that they should be just tight enough not to leak, plus 1/4 turn.
You can buy a set of thin wall sockets at Lowe's or similar, and they are handy. But....you may be able to slip a deep well socket onto the nut and turn it. This will save you ~$15, if it works... Unless you are familiar with adjusting packing glands, it will be easier to just replace the entire valve. Get a socket that will fit the valve body. Place the socket on the valve; the stem will have to pass through the square socket drive hole. You will have to use a pair of channel locks or pipe wrench (or similar) on the socket to remove the valve cartridge. When you have the valve out, look inside the valve with a flashlight and you'll see the valve seat. It will have a square or hexagonal hole in it. Check with your finger for nicks. If it is damaged, remove it. The valve seat wrench is available at a hardware store reasonably, ~$10. Pull the valve out and take it with you to the hardware store. Reinstallation is the reverse of the removal with two exceptions: make sure that the valve stem is "open", and make sure that the packing gland is snug, but not too tight. The easiest way to adjust it is to put the handle on the valve and to operate the valve in your hand. Tighten the gland to snug and operate the valve. Make adjustments in this manner until the valve is still easy to operate, but is getting harder to operate as you tighten it...you'll get the feel for it. Once you're satisfied for the most part, install the valve. Usually there is a plastic gasket or "O" ring that will need to go on the threads. Install according to the instructions included. Once the valve cartridge is installed, operate the valve a few times. Complete the reassembly.
Regards, --W/D--
Posted on Jul 14, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: Cracked lower casing of Jandy valve leaking some
There are some products out there that will fix the body but most claim they are 'temporary' repair products for use until a new piece can be installed. Your experience may differ so you could at least try it. For most of the pools we have used epoxy on it is only good for a season or two in Michigan before the freeze/thaw cycle does in the repair.
Your local pool store or home center will have these products; you just need to know what the valve was made of (usually sch 80 pvc).
Posted on Dec 18, 2009
uspartscente
US Parts Center
  • 719 Answers
SOURCE: How do you remove Jacuzzi Waterfall handles to get
On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
Posted on Jan 12, 2011
uspartscente
US Parts Center
  • 719 Answers
SOURCE: One of the "Air Volume Control" valves shoots
you can change out the complete air control valve. One thing i would have you do before changing that out is to make sure all of the jet faces are turned on. to do this turn the face of the jet clockwise. this will let the maximum amount of water come out of each jet face.
Sometimes if there are adjustable jets in the tub and they all get shut off, it will force the water that should be coming out of the jet faces back through the system and out the air control knob if it is open.
Just to check. that may not be the case....but...that would be cool if it were.
Posted on Jan 25, 2011
Water will not come out of m72as till turned off then back on comes out then after 10 second delay
WASHER LOOSE. SHUT OFF SUPPLY LINE TO SILCOCK. REMOVE HANDLE, LOSEN PACKING AND BONET NUTS, REMOVE LONG SPINDLE. TURN ON SUPPLY AND CK FOR FULL FLOW TO DETERMIN SUPPLY VALVE IS WORKING. TIGHTEN BIB SCREW AND WASHER REINSTALL. DO NOT OVERTIGHTEN PACKING NUT IF IT DRIPS JUST SNUG IT WHAN VALVE IS OPEN TILL IT STOPS WEEPING.
Apr 18, 2014 | American Valve M72AS-10 10 Inch Frostproof...
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
The water coming out the shower jets is not powerful, help?
If a faucet leaks, replace seals and gaskets .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
I have a Rheem 50 gallon electic water heater that seems to be leaking from the on/off lever at the top of tank. Do you have a replacement part for the on/off lever? Thanks, Cindy
If you are talking about the water valve on the cold water inlet it should have a nut under the lever if it is a quarter turn ball valve.If so you can remove the nut that hold the lever on and carefully tighten the nut by turning it clockwise.This should stop it leaking if it is coming from around the stem. If it is a globe type valve there should be a packing nut that goes around the stem under the handle. Tighten this nut carefully to get leak to stop. If it is leaking anywhere else then you will need to have the valve replaced.They are available at almost any hardware store.Thank you.
Aug 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have an an older two handle shower only. Sanyo brand or something close to that. It's got a new problem for me. When you turn on the hot valve, water will begin to leak from the cold handle, but it...
Ie there a seperate nut on the stem other than the one that holds the stem in place in the valve body. If there is then this is called a packing nut and there will be a gasket underneath it to seal down around the stem to stopit from leaking, You can try to tighten this nut down a little to see if it helps. Be careful to not force it as you can strip the threads out or break the nut.
You can see if you can get the handle off the cold side and leave the back nut in place. Check with your hardware store and see if they have any rope or string packing that you can use to make you own packing with. Wrap a small portion around the faucey stem then try to push nut into place and tughten snugly.Best of luck and thank you.
Jan 19, 2011 | Home
Sillcock leaks even when off. does anyone make a repair kit?
Have you tightened the nut around the valve or have you backed off the nut then screw it in and then tighten nut? And yes you can get a kit at any hardeware store but you will have to take it apart to get the right seals.
Jun 27, 2009 | Frost Free Sillcock, 12"
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Home Logo
11,725 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
