Question about CP Technologies - FSW-0808TX - 8-Port 10/100 Network Switch (FSW0808TX)
Forgot login & pwd - CP Technologies - FSW-0808TX - 8-Port 10/100 Network Switch (FSW0808TX)
Posted by bestomar on
Anonymous
    Scholar:
  • 136 Answers
If all else fails and you cannot remember your login information use a toothpick ir a similarly small object and press the reset button, Usually located somwhere on the back of the unit, look for a small hole the reset button is usually not visible but is just inside the small hole, press and hold this reset for 10 seconds or more and it should reset to factory defaults including the login info then you can access the unit using the factory login info. usually USERNAME: admin PASSWORD: password
Hope this helps Good Luck!!!
Posted on Jun 10, 2011
2answers
Facebook login
Point your web browser at http://www.facebook.com
If another account comes up, log out of it by clicking the little gear icon in the upper-right then clicking "Log Out."
If you then still can't log in to your account, click the "Forgot your password?" link located just below the password box on the login page.
If you're getting an error message, what does it say?
How
Are you talking about... ADMINISTRATOR'S PASSWORD, WORK GROUP PASSWORD to Server Database Login???
If you are talking about WINDOWS LOGIN at boot... try F5 or F8 to choose... DOS PROMPT(command prompt; safe mode command prompt is Ok as well)
Use the "CD" command to "change directory"... to change to the C:\WINDOWS directory---i.e...C:\Users\USER> cd C:\WINDOWS
Then use the command line... C:\WINDOWS dir /p/w
Now.... LOOK CLOSELY-- for "any files" with the extention of----
.pwd (this is the extention for "password files")
Simply......(example command line)---- del C:\WINDOWS\*.pwd
Type the word.... "exit" after first available Command Line to EXIT DOS... use CTRL-ALT-DEL to REBOOT
I forgot my secret question and answer
If you know your UID & PWD, please login into account and go to setting to change secret questions and answer. In this case you dont face any problem.
Jan 29, 2013 • Yahoo Mail
I have a Belkin Router Wireless N. I have a laptop that I am trying to add to router but i need Network Key /WEP/wpa key. I know my pass words but not these.. Please help
1.Look at the back of the router and connect your laptop to any one of the 4 grey slots
2.In your laptop open IE and in address bar type 192.168.2.1
3.It will open a belkin router setup
4.In the belkin Router page select SECURITY in the left hand side
5.It will ask u a login Pwd . its blank Click submit
6.In the next page u can see the Security Mode - If it is WEP - KEY 1 will be your PWD
7.If the PWD is WPA . The Pre shared key or password PSK will be the PWD . Uncheck Obscure PSK to view the PWD .
Forgot my password have a new laptop and can not access my secured network without my password!
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>1.Look at the back of the router and connect your laptop to any one of the 4 grey slots <br />2.In your laptop open IE and in address bar type <span style="font-weight: bold;">192.168.2.1</span><br />3.It will open a belkin router setup <br />4.In the belkin Router page select <span style="font-weight: bold;">SECURITY</span> in the left hand side <br />5.It will ask u a <span style="font-weight: bold;">login Pwd</span> . its <span style="font-weight: bold;">blank</span> Click <span style="font-weight: bold;">submit </span><br />6.In the next page u can see the Security Mode - If it is WEP - KEY 1 will be your PWD<br />7.If the PWD is WPA . The Pre shared key or password PSK will be the PWD . <span>Uncheck Obscure PSK to view the PWD .</span></span></span>
My account is locked out and it has been three days now. how can I unlock it.
Try breaking the password using pwd breaking CD(bootable) or using bootable OS CD also u can do the magic. Just reboot system using OS CD, take reapir option and when it reaches to 39 % remaining screen, using shift & F10 key u get login screen of cmd prompt,where u can type - compmgmt.msc and in user account change the pwd. and after repair option completion just do the magic using the new pwd.
Trying to connect to my wireless router it keeps asking for a network security key where would i find this as nothing has ever been put onto computer and i have tried all numbers on box
1helpful
Security code problem
reset the router by pressing and holding the reset button down for 10 seconds. Then you just have to enter in the default login details.
For this particular model:
IP: 192.168.2.1
Login: Administrator
Pwd:
(leave password blank)
Password Lost!
there is a section for forgotten passwords under you email login Press forgot password it will ask you for your email address. this is the email address that you used to sign on for that account. They will send you your password to your email address shortly afterwards.
Tip:
Don't be telling people your passwords. They are for you only.
Sean
Computers & Internet Logo
Top CP Technologies Computers & Internet Experts
Ekse
Are you a CP Technologies Computer and Internet Expert? Answer questions, earn points and help others
