Handspring Treo 90 Handheld Logo
Question about Handspring Treo 90 Handheld
I acquired a Palm Treo 90. I do not have charger. I wanted to charge the battery to see if works before purchasing a charge & sync cable. I have several Palm's now: zire21,31, M130. IIIe. Could you tell me the pins location for charging. Brief description of each pin would be helpful. Thanks, John Best
Posted by jbest52000 on
1 Related Answer
Anonymous
  • 84 Answers
SOURCE: Battery Charge
if it still has warranty, yes take it to sprint if does not try get a charger but before you buy it check if it will work on your phone.
Posted on Feb 11, 2008
2answers
My treo pro wont charge the battery. I have purchased a new battery but the problem persists. I connect the phone to its craddle and tha charging indicator turns on; however, the battery remains at...
Either the charger port on the phone is faulty or the charger itself. Try a different charger if you can and if this works, the dock is faulty, if it doesn't then its the phone. Pretty simple repair and most Treo repair centres will be able to do it.
2answers
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
My Palm Treo 500 is not charging correctly!!
If you have had this phone for a long time its probably your battery.
1helpful
Not hot syncing
I just reset it and it work. You can reset it by taking the battery out for a couple of mins, put it back in and it should work just fine.
Treo 650 wont sink
Assuming you are running Palm OS and not one of the rare beta Windows Mobile versions, here is my take on this.
Are you using a USB or Serial Sync cable? With either solution, make sure that the setting on the Palm Desktop Hotsync Manager is set to the correct setting (either USB, Serial, IR, etc). Conflicts between the cable type and the settings on your PC are common.
I prefer using USB cables since they are faster and you can tell if you are connected quicker than with a serial cable. Initiate the sync via your phone or the Palm Desktop Manager software. I have had faulty cable sync buttons and this was a good solution for me. If you haven't tried a new sync cable, you might want to.
Actually if you have time and a laptop, you can take your Treo to a Palm store and borrow one of their cables to try and sync. They were really helpful whenever I went in there.
Good luck.
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Battery Charge
2answers
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Open Questions:
0answers
HotSync Problem on Treo 90 When I press the HotSync on the Trio 90 cable (I do not use a cradle) in place of the moving red and blue arrows moving, the Microsoft Unplug or Eject Hardware icon appears in the lower right portion of the task bar. I assume this means that contact has been made between the Treo 90 and the PC. This icon remains until I receive the following message on the Treo 90: “HotSync Problem” “The connection between your handheld computer and the desktop could not be established. Please check your setup and try again. This problem began after I updated to WinDesktop_401_ENG_V, Treo90Updater11, and PMStdUpdate3171. I downloaded USBRegClean.exe and used it. Then I reinstalled WinDesktop_401_ENG_V and the problem continued. I emailed my log to Chapura Support. Unfortunately, this was done after I had uninstalled and reinstalled everything and the log did not show here a Synchronization had been established because after the reinstall, I have been unable to Synchronize. I checked the PalmOne knowledge base and did the following: I checked to make sure the cable from the HotSync was is securely attached to the USB port in the back of the PC and that the cable was securely in the Treo 90. I click on the HotSync manager, (Double arrow icon on the bottom right corner of computer screen), click on setup and then local tab and first set it to PC overwrites Handheld, this did not work, I then reset it to Synchronize, this did not work, I then reset it to Handheld overwrites P.C. This did not work. I also changed the speed settings to 9600. This did not work. I did a soft reset of the Treo 90. The reset took place, but the problem persisted. I did a hard reset, then uninstalled and reinstalled everything. However, when I try a HotSync, I keep getting the Microsoft unplug or eject hardware icon. I uninstalled all UBS ports. The problem continued. Chapura Support suggested using PalmOne’s HotSyncCheck which I interpreted to be the “USBRegClean.exe” and used it again and then reinstalled WinDesktop_401_ENG_V successfully. However, when I reinstalled Treo90Updater11, and PMStdUpdate3171, when I attempted a HotSync it failed and I continued to get the Microsoft Unplug or Eject Hardware icon. Is there a fix? Is it possible that the problem is physically located in the Treo 90? If so, where can I take it to be checked and serviced if necessary? Thank you for your attention to this problem
Top Handspring Computers & Internet Experts
Marvin
Marvin
Muzahura Frank
ray gallant
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
