Question about Sony KP-51HW40 51" Rear Projection Television
My Sony Projection TV Model # KP-51HW40 currently has a GREEN screen, no picture, and only sound coming from the TV. HELP what is the part that needs to be replaced
Posted by nanook218 on
Sonny Berry
  • Sony Master
  • 8,617 Answers
Sounds like the Green CRT drive board is needing replacement. The Green CRT could also be bad but usually the set will shut down if its the CRT, so I would try the Green CRT drive you can get one from www.tvrepairworld.com
Posted on Jun 10, 2011
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
1helpful
My sony kp-51hw40 has a green screen
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you.
I hope this helps you!
Fare well. :)
Iconoclast
1helpful
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
KP-51HW40
sounds like the tuner may be going out on the set.
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
http://servicemanuals.vstore.ca/
3answers
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
