Question about Elna 1010
My sewing machine was working fine then "clattering "noises from the bobbin area, the needle quit catching the bobbin thread. I did the following: took apart the bobbin mechanism, replaced the bobbin, replaced the needlw and re-treaded. Still the needle does not catch the bobbin thread. Any suggestions?
Posted by csstisser on
Mike Cairns
  • 3,053 Answers
Hello, css
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
My brother RL 417 makes a clattering noise when I start sewing and swallows the fabric
try a new needle--one that is for the fabric being sewed
clean under the needle plate and in the bobbin area for lint
rethread the machine top and bobbin
if the bobbin is top loading make sure the bobbin is inserted into the bobbin case correctly
if the bobbin is side or front loading then also make sure the bobbin case is inserted into the machine correctly
make sure the bobbin is not warped
make sure the thread has not come off the thread take up lever
Aug 23, 2013 | Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
When the needle goes down into the bobin area below, it catches on the "round about", so the whole point is that it misses the thread, and doesn't catch it, what can i do to fix this??
It sounds like your problem is as simple as either a bent needle or a bobbin casing that is inserted improperly. First, change your needle being mindful of the type of fabric (and thread) you are using (e.g. Size 11 ballpoint for a light knit or a size 18 jeans needle for denim). Make sure that the bobbin casing is set in correctly, and that the bobbin goes in the correct way. (i.e. Counter-clockwise for a drop-in style bobbin). This should solve your issue. Happy sewing!
Jun 22, 2011 | Juki HZL35Z Mechanical Sewing Machine
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
1,029 people viewed this question
Top Elna Sewing Machines Experts
Douglas Plant
Douglas Plant
toolmanw5687
Level 1 Expert
Chris Wetmore
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
